SpotCollector Spots to Panadapter
Ric-W5IHL
Post by Ric-W5IHL »
Is there a way to send spots from DXLab's SpotCollector to the Thetis panadapter?
Current cofig allows a click on a spot in SpotCollector to change Thetis frequency.
Tnx everybody! Rik
7000dle Blue Face
FW: v2.1.18
Thetis v2.10.x...x64
Win10
Re: SpotCollector Spots to Panadapter
AFAIK there is currently no way to do this. The spots-in-panadapter feature only works with the built-in spot client.
Is there a specific reason you need to use SpotCollectors spots?
4 ways I use or have used is via TCI using:
Current way - https://www.oe3ide.com/cluster-tci-bridge/
Previous ways - https://www.lw-sdc.com/ or https://www.log4om.com/ or https://www.swisslogforwindows.com/
w9ac
Post by w9ac »
Gary,
Thanks for the suggestion. The setup screen was very intuitive; I had it up and running in about five minutes, including the web server.
Ric-W5IHL
Post by Ric-W5IHL »
Thank Scott. Are you still using the DXLabs suite?
7000dle Blue Face
FW: v2.1.18
Win10
I am, but I don't use SpotCollector. I'm not a DX chaser.
Ric-W5IHL
Post by Ric-W5IHL »
Gary, I'm currently using TCI-Bridge but since I use DXLab, I wanted to compare SpotCollector to TCI-Bridge.
Yes to SDC too and I run it on occasion but have found it to be tricky and poorly documented.
I'm surprised SpotCollector can't send spots to other clients. Maybe I'm mistaken but does it not support the Flex panadpter?
73s Rik
7000dle Blue Face
FW: v2.1.18
Win10
Ric-W5IHL wrote:I'm surprised SpotCollector can't send spots to other clients. Maybe I'm mistaken but does it not support the Flex panadpter?
SC doesnt work with Flex either, I use either SDC or FRStacks3 for that.
