ANAN-10E (Revised) HF & 6M SDR Transceiver
Posted: Fri Mar 21, 2025 7:03 pm
by SA3ATF
Even more opportunities to pre-order, but this time it only costs $1
Fun with a new 10E IF it becomes a reality that is.
There should be a possibility for another customer category with this and maybe get some HL2 and Square with more customers if nothing else.
Re: ANAN-10E (Revised) HF & 6M SDR Transceiver
Posted: Mon Mar 24, 2025 3:32 pm
by KK2L
I just pre-ordered one. Looks good. I see it has a fan on it. Would anyone care to speculate if the fan would come on by default or is there a setting in Thetis that has to be enabled?
KK2L
Posted: Mon Mar 24, 2025 4:38 pm
by Dan
My HL2+ performed nearly as well as my 7000, which impressed me. I decided to order a 10E and hope they sell plenty of them. More success for these black box radios benefits all of us who enjoy them.
Thanks, Dan
Posted: Tue Jul 29, 2025 1:37 am
by n4frl
I hope to hear soon on delivery of the ANAN-10E. Ordered back in early May but no word yet except something about 8-weeks in the beginning but that must have been for early adopters. Has anyone heard when another batch may sent out?
Ferrell
N4FRL
Posted: Tue Jul 29, 2025 7:32 pm
by Chipp
Has anyone actually received the ANAN-10E (Revised)? It was announced in March with an 8 week lead time. I look forward to hearing feedback on the rigs performance before placing my order.
Posted: Tue Jul 29, 2025 9:28 pm
by PH7R
Chipp wrote: Tue Jul 29, 2025 7:32 pm
First batch to be shipped July 30, 2025.
Posted: Wed Jul 30, 2025 6:19 pm
PH7R wrote: Tue Jul 29, 2025 9:28 pm
What is the source of your info, please?
Posted: Wed Jul 30, 2025 6:23 pm
by PH7R
K1LSB wrote: Wed Jul 30, 2025 6:19 pm
As I am on the first batch list and received email.
Posted: Thu Jul 31, 2025 11:17 am
PH7R wrote: Wed Jul 30, 2025 6:23 pm
Thanks for the reply, do please keep us apprised as to any further updates!
Posted: Mon Aug 04, 2025 3:08 am
by Dan
This is the travel history on the one I ordered.
Posted: Thu Aug 07, 2025 6:41 pm
by syracusepro
Great, I got mine today earlier and already adjusted each band power. Very well built. LPF and output board great. Hermes falls short of this, as this 10-E is a complete radio.
Posted: Thu Aug 07, 2025 10:36 pm
by Trucker
syracusepro wrote: Thu Aug 07, 2025 6:41 pm
Interesting comment. What makes the 10-E a complete radio compared to the Hermes? (I am assuming you are talking about the Hermes Lite 2 and not the older radio from Apache Labs)
What is missing?
Okay, a little bit of reading and I see that the 10-E has a built-in audio amplifier and headphone connection as well as higher output power. Maybe, that's what you are referring to. There are add-on boards and a modified firmware that add onboard audio and a microphone input as well for the HL2. But, even then you need Thetis or a Raspberry Pi to operate the radio.
Looking forward to hearing actual user reports.
Posted: Fri Aug 08, 2025 3:04 pm
by syracusepro
The Hermes Lite 2 has one board and a little LPF board then the I/O board.
The ANAN 10-E has two boards inside, the main and the Power board, with a heavy LPF, etc board.
Also 6 meters the Hermes Lite 2 dont have, and a better FPGA of course. I got both radios, plus the ANAN G2.
The G2 has XLR (TRS 1/4) for mic only, a 3.5mm for mic only, and a 3.5mm for PTT In/Out.
The ANAN 10-E has a mic in 3.5 mm jack, but also PTT. So differs from the G2 as this is Mic in and PTT in.
Other connections can be done via the ACC connections.
Posted: Fri Aug 08, 2025 4:28 pm
The only problem with the HL2 is the 12 bit ADC. In all other ways it is as good or better than a 10E. Consider that you can assemble a 100W, Thetis-compatible, radio for under $700 USD. If you are willing to give up two S units of receiver dynamic range it's a smoking deal.
Posted: Fri Aug 15, 2025 9:05 pm
by PH7R
Does anybody know what the latest Firmware is for Anan 10-E? Today received 10-E with Ver 1.5 and protocol 1.
Does firmware update work the same as with a HL2 ie rbf file with Spark? The manual is not up-to-date with Spark info on this subject.
73 Ronald PH7R
PS my trustworthy HL2 has FW 7.3.2 with board ID 5.
Posted: Fri Aug 15, 2025 11:44 pm
PH7R wrote: Fri Aug 15, 2025 9:05 pm
73 Ronald PH7R
The firmware and firmware update process for all Apache hardware (all derived from the original Hermes design) is 100% different from the HL2.
Take a look at the tacked topics here:
viewforum.php?f=18
The Git link will take you to the latest Protocol 1 firmware for all Apache hardware. For the 10E that is version 1.5. However, the Protocol 2 firmware on GitHub is not the latest. If you want to try Protocol 2, take a look in this topic:
viewforum.php?f=32
I strongly recommend the use of Bootloader to make any changes in the firmware. And it would be prudent to have a copy of the 1.5 .rbf file available if things don't work out and you want to revert back.
Did they put an external Bootloader switch on the new 10E, or do you still have to crack it open and place a jumper?
Posted: Sat Aug 16, 2025 7:33 am
by PH7R
w-u-2-o wrote: Fri Aug 15, 2025 11:44 pm
Thks for the info, will read the topics.
The new Anan 10E has an opening in the bottom (see picture). Also purpose for cooling (I assume).
- IMG_4112.JPG (2.03 MiB) Viewed 3268 times
Posted: Sat Aug 16, 2025 3:46 pm
by Trucker
Not big enough to provide cooling. But, it allows inserting a small screwdriver ( or something thin) to move the bootloader switch back and forth.
Posted: Wed Aug 27, 2025 12:25 am
by afilip
I received new ANAN-10E yesterday.
After unpacking it my first impression was positive, the enclosure is very well design.
I powered it on and to my very nice surprise the fan on the top of the enclosure was very quiet while working.
Despite working quietly it's blowing a lot of air on the enclosure.
The unit came with default IP address 255.255.255.255 which I changed using HPSDRBootloader 2.00.
Bootloader switch is accessible at the bottom of the enclosure. HPSDRBootloader found the board with no problem.
The ANAN-10E has firmware ver. 1.5, ID Hermes, Protocol1.
I've checked what max transmit power is available on each band using dummy 50 ohm load.
The power was displayed on Thetis TX meter.
160m - 16W;
80m - 15W;
40m - 21W;
30m - 19W;
20m - 22W;
17m - 20W;
15m - 19W;
12m - 17W;
10m - 13W;
6m - 9W.
The test on the air will follow possibly tomorrow.
Posted: Wed Aug 27, 2025 1:38 pm
If you're not aware, the PA Gain adjustments and Watt meter trim adjustments should be adjusted by the user for each band. Don't rely on the factory settings to be accurate! Those settings are found in the PA Settings tab and its subtabs in Setup.
You will need a calibrated external power meter to make those adjustments. It's a rather time-consuming process to adjust those settings so I would strongly suggest that you save your finished settings somewhere safe in case you ever need to reset your database.
Posted: Tue Nov 04, 2025 8:05 pm
by DO7DV
While I like my new Anan-10E (Revised) in general, its top fan is something I dislike very much.
From my point of view it is way too loud. Maybe it is just my unit.
My experience with HF transceivers is limited, but most other radios I encountered were somewhat quiet.
It was hard to tell if they were switched on or off, just by listening to their noise output.
The little Anan is so loud that it's unbearable to have him next to me on my desk.
The fan is connected with two wires only. To me this means its most likely has no rpm reporting.
From that I would assume, that the device can not really control the fan.
In best case, it would switch between some resistors to limit fan speed to a few levels.
But it does not.
An advantage: The fan moves a lot of air and the device remains cool in standby operation.
I did not test it with prolonged FT8, but I don't think it will get very hot in this configuration.
Posted: Tue Nov 04, 2025 9:23 pm
Most, but not all, of the Apache thermal designs relied on using the case as the heat sink for at least the final amplifier transistors. Most of these designs had internal fans but the do very little other than stir the air around inside to keep the power supply and digital boards sort of cool. In these designs, free convection over the exterior of the case was never enough to prevent overheating except under relatively low ambient temperatures. Many folks, particularly those running 50W digital, or AM, found it necessary to add just a little bit of airflow over the exterior of the case to actively carry away the heat produced. Some folks even added on heat sink fin material to the exterior.
To that end, it's good to see that Apache chose to include the fan on the new 10E, but it's unfortunate to read that it is noisy. The good news is that you can probably replace it with a much, much quieter fan and still be fine. As already mentioned, it takes surprisingly little active airflow to make a huge difference in case temperature.
Here is an old article about exactly this subject as it applied to one of the legacy 100W designs:
http://wu2o.dyndns.org/wu2o_fans.html
Posted: Wed Nov 05, 2025 5:14 pm
by DO7DV
When looking at pictures of the old Anan-10E one could think, they changed the case to a cheaper, thinner metal version.
Obviously heat would be a problem, so they slammed on a fan.
I would have paid 25 Dollars more, if the device had a capable but quiet fan design. Now I have to do the mod with a Noctua myself.
It is a 80mm fan, while the case would allow 92mm. There might be some internal downsides, I am not aware of.
With the fan outside of the case, it does not cause dust issues inside.
Because I like the Anan-10E (Revised), I placed an order for the G1. This looks more like a passive design, but lets see what surprises we might find there.
