Anan 10E (revised)
LA7THA
Anan 10E (revised)
Post by LA7THA »
Does the Anan10E (Revised) have two independent ADC. Copy and paste from the Technical description "Supports 2 fully independent receivers"
I am tinkering two Independent ADC / coherent for diversity beam forming.
Rune LA7THA
Re: Anan 10E (revised)
It only has a single ADC.
Not only is this historically accurate (the original 10 and 10E only had a single ADC), but the rear panel connectors pictured do not show an input for a second ADC as implemented on all other Apache models with dual ADCs.
The ad copy probably should have stated that the firmware supports 2 DDCs.
LA7THA
Post by LA7THA »
Ok, all understood. For the information, I am using this with my Red Pitaya and do beam forming on a 8 circle RX array.
BSEF: Two front element separated about 90+ meters then, coax from each element to a magic T. The same setup for the back elements that also go to a magic T. From each magic T, 2 x 1000 feet of RG6 to each receiver. Maybe I need to invest in a G2 then :-)
