wsjt remote audio
Posted: Mon Sep 15, 2025 6:47 pm
by Joel1
Is it possible to run piHPSDR on my ANAN G2 Ultra with panel and WSJT on my PC ( Windows ) and get the audio back and forth over LAN?
I have cat control working no problem but can't get the audio to work. Seems like most of what I'm finding is for the SDR software and WSJT to both be running on the same machine.
On the rPI I have set up virtual sinks, but not sure how to connect them to LAN. I'm starting to think my approach is bad from the beginning.
I have tried Voice Meeter Banana which seemed close, but still no connection.
what is the solution?
Joel
Re: wsjt remote audio
Posted: Mon Sep 15, 2025 10:50 pm
It would be a lot simpler to run WSJT-X on the G2 itself. There is a Linux version.
Posted: Mon Sep 15, 2025 11:42 pm
by Trucker
w-u-2-o wrote: Mon Sep 15, 2025 10:50 pm It would be a lot simpler to run WSJT-X on the G2 itself. There is a Linux version.
But, would the CM4 Pi have enough horsepower to run it along with PiHPSDR?
Posted: Tue Sep 16, 2025 12:43 pm
Trucker wrote: Mon Sep 15, 2025 11:42 pm
There's an easy way to find out ;)
One would think somebody has done this already.
Posted: Tue Sep 16, 2025 4:06 pm
by Joel1
For me, I have been using my PC to run wsjt-x or jtdx for many years, connections are there, logbook is there, prefer to keep it there.
Still would like to know if there's a way to do audio over the LAN.
Posted: Tue Sep 16, 2025 5:37 pm
I'm 100% positive there is a way to do this. If this was Windows-to-Windows I could tell you exactly how. Unfortunately, short of doing the same Google searches you would, I don't know off the top of my head which app's to use.
A quick Google search shows that JACK runs on both Linux and Windows. I remember using JACK on Windows way back before there was Voicemeeter. https://jackaudio.org/downloads/
There is also PipeWire for Linux, but it does not seem to be available on Windows. https://pipewire.org/
Posted: Tue Sep 16, 2025 8:42 pm
by Joel1
Thats what I have been looking into and trying. I have a null-sink setup on the CM5 and I have tried just virtual audio cable and voice meeter banana. still no luck. I think Thetis has a more explicit setup for a virtual audio channel. Once I exhaust trying with piHPSDR, I might try Thetis.
Posted: Tue Sep 16, 2025 9:44 pm
There is no VB Audio app that will work in this case. They are Windows only, and will not interface with any Linux-based solution. I.e., you've been going down the wrong road with those tools.
I'd strongly recommend you install JACK on both the CM5 and the Windows PC and see if you can get the two JACK instances communicating over the LAN.
Thetis and WSJT-X on the same Windows PC is completely trivial to interface.
Posted: Tue Sep 16, 2025 10:43 pm
by Joel1
It also looks like running pulseaudio on both machines might work. Jack also looks like a possibility, or a combination of both. So far what I have been reading is in the context of only going in one direction. Still trying to find the right bi-directional answer.
The VB-audio answer was just for the windows side with running pluseaudio server on the linux side, but it does seem like there are better answers.
It does seem possible.
Posted: Wed Sep 17, 2025 1:42 am
by Joel1
Off topic, I did get it working on Thetis, was pretty simple just using VB-Audios basic virtual audio cable.
Still working on the piHPSDR solution
Posted: Fri Sep 26, 2025 2:38 pm
by ct1iqi
Am streaming received audio here from a G2 with Radxa CM5 where Pihpsdr runs, to internet.
The trick is indeed to define Pulseaudio virtual sinks, two of them when you want two-way comms. These Pulseaudio sinks automatically create monitor sources that can be used to pick up the audio signals.
Just install ffmpeg on the G2 and make one instance send and one instance receive audio.
A command example to make ffmpeg send mp3 compressed audio from the G2 to an Icecast server on internet from where many people can pick up the audio:
ffmpeg -ac 1 -f pulse -i stream_sink.monitor -acodec libmp3lame -ab 32k -ac 1 -content_type audio/mpeg -f mp3 icecast://source:<password>@<ip address>/<stream name>'
ffmpeg can virtually do anything, so just make it send what the app on your Windows system understands, and vice-versa.
To create two sink put 'default.pa' in /home/pi/.config/pulse with contents
.include /etc/pulse/default.pa
load-module module-null-sink sink_name=stream_sink sink_properties=device.description='stream_sink'
load-module module-null-sink sink_name=digmode_sink sink_properties=device.description='digmode_sink'
Here I can just run WSJTX or Fldigi on the G2 locally. The ffmpeg bit is not needed in that case, but the sinks still are neede to interface to Pihpsdr, also native.
Posted: Fri Sep 26, 2025 11:54 pm
If ffmpeg is the answer, as good as it is it is still a PITA to use by mere mortals.
I'm assuming that ffmpeg will also be required on the Windows side?
Perhaps something like this might make it easier: https://qwinff.github.io/
Posted: Sat Sep 27, 2025 8:11 am
by liam
Posted: Sun Sep 28, 2025 10:50 am
Remaud is Window-only. Since the OP wants to create an audio channel between a Linux machine and Windows Remaud is not going to work.
