CW MOX full power
Posted: Wed Nov 12, 2025 10:32 pm
by W9IP
I use an Angelia board as the i.f. for VHF work. I recently tried to do CW but ran into a problem. In CW mode, with no CW key plugged in, clicking the MOX button or otherwise engaging PTT puts the radio into key-down transmit. In other words, MOX acts like TUNe. Nothing on the Setup/DSP/CW tab is checked; connections are both "None." VAC makes no difference.
The only thing I can think of is that the CW jack is messed up. Before I take everything apart, perhaps someone has another suggestion.
Michael, W9IP
Re: CW MOX full power
Posted: Fri Nov 21, 2025 1:30 am
by W9IP
Solved the puzzle. The "Dash" port in U25, a buffer, was faulty. I replaced the chip and all is good.
W9IP
