DX / SWL Spotter remove map grid?
DH1KLM
Post by DH1KLM »
is there a way to remove the grid in the worldmap pic which is shown if "Track" is active in DX / SWL Spotter?
I always see both grids, the one from Thetis and the other one from DX/SWL Spotter.
I assume the shown grid is part of the pic itself and can not be removed.
Maybe it is possible in a newer version from KE9NS.
Of course it is also possible to deactivate the grid in Thetis, but I don't like that.
I also noticed that "Time Sync" is not working.
Obviously NIST Time Server cannot be reached.
But it doesn't bother me, since the time is synchronized via Windows anyway.
NC3Z
Re: DX / SWL Spotter remove map grid?
Post by NC3Z »
Have you tried selecting Disable picDisplay under Appearance > General or alternately adjusting the Alpha of Appearance > Grid > Background
DH1KLM
Post by DH1KLM »
I assume you misunderstood something.
Deactivating picDisplay does not hide the grid on the DX/SWL Spotter worldmap, the worldmap pic completely disappears. Also adjusting the Alpha of Appearance> Grid> Background is not useful because it only changes the grid in the RX display and not that of the worldmap.
It's just a purely cosmetic thing, I just don't like the fact that the worldmap pic has its own grid, which also has no real benefit.
I think the worldmap pic could be replaced, but apparently it is embedded directly in Thetis.
At least I couldn't find it in the skin directory or anywhere else.
NC3Z
Post by NC3Z »
DH1KLM wrote:I assume you misunderstood something.
Probably my first suggestion was, but that is why I suggested maybe the Alpha slider may do something you wanted. But without seeing what you were expecting it was just suggestions, other than that I am not sure there is a user solution.
W3MMR
Post by W3MMR »
The grid is part of the actual photo used for the map
Perry
DH1KLM
Post by DH1KLM »
Already replaced it with another one. I have to test a few others as well.
I also changed the non working timeservers in DX/SWL Spotter.
It's not really important, but it annoyed me that the function didn't work.
W3MMR
Post by W3MMR »
DH1KLM wrote:Already replaced it with another one. I have to test a few others as well.
Where was the map photo, in which directory? I wouldnt mind changing mine as well. I make all my own skins as well. Just wish the DX spotting and VOACAP actually worked with the map as well.
Perry
DH1KLM
Post by DH1KLM »
It is not possible to change the pictures without compiling the whole thing.
W3MMR
Post by W3MMR »
DH1KLM wrote:It is not possible to change the pictures without compiling the whole thing.
One day my friend, one day!
Perry
