Thetis 2.7.0
DH1KLM
Thetis 2.7.0
Post by DH1KLM »
FYI, Thetis 2.7.0 sources out now.
https://github.com/w5wc/Thetis-2.7.0
Compiled it yesterday and did a short test.
Look's OK so far, but have to play around a bit more.
DL8LAQ
Re: Thetis 2.7.0
Post by DL8LAQ »
Hi Sigi,
I would like to test your compiled files. I don't know how to compile the sources on my windows pc, maybe we can talk by phone oder teamspeak.
DL8LAQ
Re: Thetis 2.7.0
Post by DL8LAQ »
Hi Sigi,
I did install Visual Studio 2019 yesterday and it seems to works. Just tested the self-compiled 2.6.9 and 2.7.0.
I just tried to TX with my 2-m-band-xvtr, but failed due to not working ptt control. The xvtr ptt is connected to the rear panel rca jack on my ANAN-7000.
I switched back to 2.6.9c3 by Richie.
4z1ao
Re: Thetis 2.7.0
Post by 4z1ao »
Compiled it too.
Played a bit with the Release version. Looks good so far.
73 Isaac 4Z1AO
DL8LAQ
Re: Thetis 2.7.0
Post by DL8LAQ »
4z1ao wrote:Compiled it too.
Hi Isaac,
can you please try to setup for a 2-m-xvtr and check the ptt output on your radio?
NJ2US
Re: Thetis 2.7.0
Post by NJ2US »
Are there any release notes for 2.7.0? Can anyone summarize the difference between this version and 2.6.9?
Jeff NJ2US
DH1KLM
Re: Thetis 2.7.0
Post by DH1KLM »
DL8LAQ wrote: I switched back to 2.6.9c3 by Richie.
I recommend to ask Richie about the changes.
Maybe he could point you in the right direction.
too bad that Richies source files are not visible, otherwise you could search for the differences in the XVTR control yourself. Today I try to connect the Alex interface and report back what the XVTR PTT does for me.
Re: Thetis 2.7.0
AFAIK, Richie is taking a break from coding. That means any changes are most likely from Doug and Laurence and associated with the Andromeda project.
W4WMT
Re: Thetis 2.7.0
Post by W4WMT »
jeffreydoran wrote:Are there any release notes for 2.7.0? Can anyone summarize the difference between this version and 2.6.9?
Jeff NJ2US
It's kind of difficult to know, because 2.7.0 has forked off into a completely new git repository, and so we can't do a simple diff to see all the changes.
I just did a file compare in WinMerge between 2.6.9 and 2.7.0 in W5WC's GitHub. All the low level stuff is exactly the same, ie zero changes in WDSP and The ChannelMaster. Many changes were done in the Console and Setup classes. The Console is a scary and confusing place that dates all the way back to the SDR-1000 days at Flex, so it's hard for me to understand what all the changed were. My sense, after scanning quickly through all the changes, is there was a lot of code cleanup, housekeeping, and some modest refactoring in Console and Setup.
4z1ao
Re: Thetis 2.7.0
Post by 4z1ao »
DL8LAQ wrote: Hi Isaac,
I'll try and let you know.
DL8LAQ
Re: Thetis 2.7.0
Post by DL8LAQ »
4z1ao wrote:
DL8LAQ wrote: can you please try to setup for a 2-m-xvtr and check the ptt output on your radio?
I think it's ok now with f/w Orion_MkII_NP_v2.0b! Now I can use the self-compiled 2.7.0. The footswitch is working in CW and the PTT out is active, that means the PA PTT or the XVTR is controlled by footswitch! That is what I missed for long time!!!!
By the way, the PTT by space bar seems to not work now - yes, I enabled MOX by space bar - but that is no problem since the footswitch is available in any mode.
Thank you guys for fixing this :-)
DH1KLM
Re: Thetis 2.7.0
Post by DH1KLM »
Hello Norbert,
good to hear it is working now.
For spacebar PTT have a look at the pic.
DL8LAQ
Re: Thetis 2.7.0
Post by DL8LAQ »
DH1KLM wrote:Hello Norbert,
Hi Sigi,
that is the solution. Thank you! :-) Enable shortcuts was not ticked.
GW0DQW
Re: Thetis 2.7.0
Post by GW0DQW »
Space bar working Norbert , thank you very much .
Chris
GW0DQW :)
dj1yr
Re: Thetis 2.7.0
Post by dj1yr »
have compiled thetis 2.7.0, if you want to test, please ...
https://www.file-upload.net/download-13 ... 0.zip.html
Re: Thetis 2.7.0
Thanks but could not get this working, radio would not switch on . back to 2.6.9
dj1yr wrote:have compiled thetis 2.7.0, if you want to test, please ...
dj1yr
Re: Thetis 2.7.0
Post by dj1yr »
Did you choose the right radio?
Re: Thetis 2.7.0
I presume so as it updated existing database.
DH1KLM
Re: Thetis 2.7.0
Post by DH1KLM »
I had the same experience when updating an existing database.
Obviously the radio model is not updated in Setup> General> H / W Select.
I noticed this behavior even after importing an older database. The radio was then set to HPSDR instead of Hermes.
But I think that most of the other settings were adopted, at least I could not find any other differences.
dj1yr
Re: Thetis 2.7.0
Post by dj1yr »
It was the same with me
Re: Thetis 2.7.0
Thanks guys you were right, the correct radio was not selected . Seems to be working on RX so far.
Re: Thetis 2.7.0
2.7.0 does not seem to remember the last TX mode on startup , anyone else seeing this ?
rbduck
Re: Thetis 2.7.0
Post by rbduck »
I'm having no issues with Thetis 2.7.0 remembering the TX mode on startup
DK1WP
Re: Thetis 2.7.0
Post by DK1WP »
After the first start of 2.7.0 under General -> H/W Select the correct transceiver was not taken over.
Also the audio profile (Transmit Filter as well as CFC settings) had to be adjusted.
All other settings like PA Settings, Display, CAT were taken over from 2.6.9.
Marcus
Re: Thetis 2.7.0
Yes the database upgrade did not capture the mode so has to be set correctly and saved again under the correct TX profile.
Edit: Tested again and the program resets every time to LSB when profile was set to DIGU
rbduck
Re: Thetis 2.7.0
Post by rbduck »
In this case yes. The first time I started 2.7.0 I had to go through and correct many settings that did not come over from 2.6.9. After that I had no issues.
Re: Thetis 2.7.0
Yep definitely an issue here , no matter what I do it goes back to LSB on startup unless I'm missing something obvious. Not a big deal either way
dalemitchell
Re: Thetis 2.7.0
Post by dalemitchell »
Where can i download Thetis 2.7.0 $
dj1yr
Re: Thetis 2.7.0
Post by dj1yr »
dalemitchell
Re: Thetis 2.7.0
Dale
