PTT IN or DIG IN 1? R LINE IN and L LINE IN?
OE3JRC
Post by OE3JRC »
I have two questions concerning the rear panel of my brand new 7000DLE MkII (black).
I use the microHAM CW KEYER.
The KEY output of the CW KEYER is connected with DIG IN 2.
The PTT output of the CW KEYER is connected with PTT IN.
This works fine, but is it possible to use DIG IN 1, instead of PTT IN?
I understand that R LINE IN and L LINE IN are meant for connecting a soundcard for digital modes. Is this correct? Can I use them for other purposes too?
TNX and 73, Hans PA0Q.
Hans Remeeus (PA0Q/OE3JRC)
https://pa0q.nl
OE3JRC
Re: PTT IN or DIG IN 1? R LINE IN and L LINE IN?
Post by OE3JRC »
Thank you Helmut!
I will try only DIG IN 2 for the keyer, without PTT.
Another question: has PTT OUT on the ANAN the same function as DIG IN 1, but buffered on the DIG IN 1?
LINE IN L and R I will not need at this moment.
TNX and 73, Hans.
https://pa0q.nl
pa1hr wrote:Another question: has PTT OUT on the ANAN the same function as DIG IN 1, but buffered on the DIG IN 1?
DIG IN 1 is an input. The current software uses it as a TX inhibit signal, as already mentioned above.
OE3JRC
Post by OE3JRC »
Thanks Scott!
The manual is not very clear on these items.
73, Hans.
https://pa0q.nl
