USB to Serial Adapter for PTT
LarryW
Post by LarryW »
So---PTT is working great using this method, however I notice if I shut down the PC or reboot the PTT does not work unless I unplug the usb/serial adapter then plug it back in.
I always start the PC first then the radio (maybe it should be the other way)
Anyone run into this issue and if so, what was your fix?
Thank You,
Larry
N7ZDR
7000 mkll Thetis v2.8.11 21k3
P2_v2.0b
w9mdb
Re: USB to Serial Adapter for PTT
Post by w9mdb »
What serial adapter do you have? Sounds like it's buggy.
LarryW
Post by LarryW »
Mike,
Using this one--see Picture
USB Serial Adapter.JPG (104.77 KiB) Viewed 8070 times
P2_v2.0b
w9mdb
Post by w9mdb »
It doesn't say it's an FTDI chip -- is it using an FTDI driver?
Every one I've seen that's FTDI says so.
LarryW
Post by LarryW »
No I don't think it has the FTDI chip. When I was looking for one I never thought about that. It came with a cd for the driver bit it found in online quickly so thought it would work.
If it continues I will order a different one I guess!
Larry
P2_v2.0b
w9mdb
Post by w9mdb »
If it's a Prolific you have to downgrade the driver to get it to behave.
https://www.miklor.com/COM/UV_Drivers.php
I hang on to an early Prolific driver for just such occasions, I hope it came across as an attachment.
early_Prolific_PL-2303_driver_(ver.3.2.0.0).zip
(1.77 MiB) Downloaded 593 times
