So---PTT is working great using this method, however I notice if I shut down the PC or reboot the PTT does not work unless I unplug the usb/serial adapter then plug it back in.
I always start the PC first then the radio (maybe it should be the other way)
Anyone run into this issue and if so, what was your fix?
Thank You,
Larry
N7ZDR
USB to Serial Adapter for PTT
7000 mkll Thetis v2.8.11 21k3
P2_v2.0b
P2_v2.0b
Re: USB to Serial Adapter for PTT
What serial adapter do you have? Sounds like it's buggy.
Mike,
Using this one--see Picture
- USB Serial Adapter.JPG (104.77 KiB) Viewed 8059 times
P2_v2.0b
P2_v2.0b
It doesn't say it's an FTDI chip -- is it using an FTDI driver?
Every one I've seen that's FTDI says so.
No I don't think it has the FTDI chip. When I was looking for one I never thought about that. It came with a cd for the driver bit it found in online quickly so thought it would work.
If it continues I will order a different one I guess!
Larry
Larry
P2_v2.0b
P2_v2.0b
If it's a Prolific you have to downgrade the driver to get it to behave.
https://www.miklor.com/COM/UV_Drivers.php
I hang on to an early Prolific driver for just such occasions, I hope it came across as an attachment.
- early_Prolific_PL-2303_driver_(ver.3.2.0.0).zip
- (1.77 MiB) Downloaded 593 times
