Anan-8000 no audio
46flatlander
Re: Anan-8000 no audio
Dear Scott,Thank you for your help,I sent him an email!
Hi Jack,46flatlander wrote:Dear Scott, Do you have access to a USA phone number for Apache? I have sent them 3 emails concerning repair NO response!
I registered at their site ,they were going to send password,hasn't happened.Do you know of any reputable repair service ?
I love the radio and don't want to return to Flex,but this situation is really frustrating. Thanks to you and Mark for all your help
Jack Lee W1JAC.
On Dec 19 in the "Apache Labs News" sub-forum, they announced that their offices were closed through the holidays and would reopen Jan 4. Bad timing for you, unfortunately.
Sounds like, from all the postings above, that it would be a good idea to send your 8000 to Doug for a thorough a checkout.
46flatlander
Dear Bryan, Thanks for your input I have already contacted Doug and will send the radio for "tune up", but here's
something for Scott and Mark to ponder. I used Scotts walk through and set up radio to USE VAC1 ,from what I could tell
I had clean audio,recorded on Audacity ! But the radio doesn't transmit? Mark I down loaded the software you mentioned
but didn't install. Thanks again
In VAC setup make sure the bypass on PTT options are turned off. Then it will transmit with VAC audio.
46flatlander
Happy Resolution to bad audio ! Sent radio to Doug US service tech! He found the problem,made repair (minor) and had radio on it's
way after one day and he treated me fairly! So I learned an expensive lesson don't hot swap condenser mic !
Seriously? That should not be a problem. The maximum bias output of the TLV320AIC23B CODEC is 3ma. There is a 3.3K series resistor on the output circuit that would limit the 2.75V bias voltage (3/4 of the 3.3V supply voltage to the CODEC) to 0.75ma. So a short circuit should have no effect. There are two TSS5A3259A analog switches between the CODEC bias output and the microphone jack. These are rated for 200ma.46flatlander wrote:So I learned an expensive lesson don't hot swap condenser mic !
Bottom line: there is no way hot swapping microphones should damage any component.
Which IC was replaced? Do you know?
46flatlander
Scott, All I know is two analog switches.
Wow that's crazy. It makes no sense.
