File is not in the correct format
W4NNG
Post by W4NNG »
RE: Thetis 2.8.11
Getting 'File is not in the correct format' when I start Thetis. Get the same error as at the link below
https://apache-labs.com/community/viewt ... rmat#p4033
but the offered solution...
C:\Users\<your user name here>\AppData\Roaming\FlexRadio Systems
...is not applicable. I'm not seeing the \AppData\Roaming\FlexRadio Systems
Thanks for any suggestions
Re: File is not in the correct format
Read first post here: https://apache-labs.com/community/viewt ... f=6&t=2975
Last two lines of that post in particular.
W4NNG
Post by W4NNG »
Thanks Scott
Minor point -- 'AppData' is a hidden file, so in File Explorer click View Tab then , if needed, check 'Hidden Items'
C:\Users\username\AppData\Roaming\OpenHPSDR\Thetis-x64
Delete Thetis-x64
If you type the path manually into the File Explorer path box you don't have to change For Explorer options.
