Birdie repeating every 100kHz
JJ4SDR
Post by JJ4SDR »
I am not sure if this is hardware or software related (perhaps this has nothing to do with the ANAN 7000 DLE MKII at all), but on 17,15,10 and 6 meter bands I see a "birdie" that repeats every 100 kHz. Any suggestions on where to look? Running Thetis 2.8.11 (10/20/20).
Best!
w9mdb
Re: Birdie repeating every 100kHz
Post by w9mdb »
Can you post a snapshot?
JJ4SDR
Post by JJ4SDR »
See 3 images (6/10/12 meters) to give some idea. Yes, the 12 meter images shows birdies out of band, but they repeat every 100kHz.
Birdie on 12 meters.jpg (210.36 KiB) Viewed 10346 times
Birdie on 10 meters.jpg (208.41 KiB) Viewed 10346 times
Birdie on 6 meters.jpg (211.03 KiB) Viewed 10346 times
Not a Thetis issue (moving the topic).
Have you tried a different power supply? Run the ANAN off of a battery? Run around the house turning off circuit breakers?
w9mdb
Post by w9mdb »
I'm seeing similar birdies on my 7000DLE MKII.
Have to hook my ANAN100 again and see if it sees them.
It's a CW signal with a quickly varying amplitude. Wonder if it's some internal oscillator?
PD3LK
Post by PD3LK »
Try disable 6m LNA RX and TX : Setup, General, Ant Filters, tab BPF1/LPF
(for SDR-Console users: do the same)
73 PD3LK
w9mdb
Post by w9mdb »
6m LNA enabled or disabled makes no difference.
PD3LK
Post by PD3LK »
Is it still there when you disconnect/shorten antenna inputs?
w9mdb
Post by w9mdb »
Yes...still there.
But that did help to identify what appears to be the source at 4.953MHz
It's -85dBm but reduces a lot when enabling the 60M antenna connection.
Screenshot 2021-10-25 155340.png (14.93 KiB) Viewed 10278 times
PD3LK
Post by PD3LK »
nasty : ( i suspect it's coming from your (switching?) PSU.
Try another one or a battery as Scott advised.
JJ4SDR
Post by JJ4SDR »
w-u-2-o wrote:Not a Thetis issue (moving the topic).
Scott!
Will try it. Right now I am using (my preference) a linear PSU by Astron. I have a SPS too.
w9mdb
Post by w9mdb »
I identified my problem...it is my 2nd Bodnar GPS sitting at 4.593 but it's creating harmonics like crazy which it seems should not happen.
That's interesting, Mike. I have a mini-Bodnar, but it lives two stories above the main radio rack, and if it's throwing off any RFI it's not been apparent here. Is yours the full size or mini? And it's programmed to 4.593 MHz? That's kind of an odd freq?
w9mdb
Post by w9mdb »
MIne's plugged into the rig on Ant2....I use a programmable attenuator
I have 3 of them for doing different frequency testing across rigs and such.
That just happened to be the last frequency I was testing.
With 48dB attenuation it clears up a lot. Much less than that and the noise floor on the wideband display goes up dramatically.
So any signal over about -90dB is causing bad effects.
w9mdb wrote:MIne's plugged into the rig on Ant2....I use a programmable attenuator. I have 3 of them for doing different frequency testing across rigs and such.
That just happened to be the last frequency I was testing. With 48dB attenuation it clears up a lot. Much less than that and the noise floor on the wideband display goes up dramatically. So any signal over about -90dB is causing bad effects.
The Bodnar units are not very good for such purposes if you are worried about harmonics. The output of the Bodnar units are square waves. So of course you are going to get odd-integer harmonic frequencies of the form 2π(2k − 1)f.
If you are concerned about harmonics in your experiments you should probably get a real signal generator that you can lock to the GPS reference. Or you could build low pass filters for the Bodnar for each frequency you want to use.
JJ4SDR
Post by JJ4SDR »
Tried unplugging a few wall-warts but no difference. Then I looked at my YETI emergency power supply (I am supposed to keep in plugged in at all times) and decided to switch it off. All birdies or "spurs" gone.
