I thought it was from my temporary desktop, but it appears it's within my 200D. It's a steady S-8 (-79dBm) at about 3938.5kHz and ever so slowly drifts low in frequency. I found a few more similar ones, on 2624kHz, 3283kHz and 4591kHz.
Any thoughts as to a remedy? Screenshots are attached.
Thank you,
73 Kriss KA1GJU
Strong Birdies in 75/80M
Kriss - KA1GJU
- UpClose.png (932.8 KiB) Viewed 5010 times
- Antenna.png (888.64 KiB) Viewed 5010 times
- DummyLoad.png (834.99 KiB) Viewed 5010 times
Re: Strong Birdies in 75/80M
Hi, if you have the 6m pre-amp on then try to set it off. It helped me with my 7000
r/Leon
r/Leon
Kriss - KA1GJU
Turned 6M pre-amp off, no change.
Thanks for reply though!
73 Kriss KA1GJU
73 Kriss KA1GJU
Moved: not an SDR Console topic.
Kriss - KA1GJU
OOPS! Sorry about posting in wrong location. Not used to this forum, I'm more of a Groups.io guy.
Anyway... any ideas from the folks here? Do all 200D's exhibit this behavior?
Here's the version: 73 Kriss KA1GJU
The 6M preamp will have no bearing on this problem given that it is on 80M.
As far as I know, nobody has ever experienced an S9 birdie (internally generated spur).
I see you have run the unit into a dummy load. Have you also tried running the unit off a battery instead of a power supply?
On my 200D I do not see any of these spurs with a dummy load in place. There are no spurious emissions at all that I can see in this range. Peaks of that size are more likely to come externally rather than from the rig. Or possibly a fault in the rig?
73 Dave G3ZQH
73 Dave G3ZQH
