Can't adjust AGC as I would like to
JJ4SDR
Post by JJ4SDR »
Embedding an image here.
For some reason I am not able to adjust the AGC level farther down as exhibited in this image. I don't think I had this issue previously. What gives? It appears that I don't have this problem on other bands.
Don't pay attention to the "bump" up the band. That is caused by an inverter inside my YETI Goal Zero emergency battery.
AGC levels.jpg (421.16 KiB) Viewed 2512 times
PD3LK
Re: Can't adjust AGC as I would like to
Post by PD3LK »
Hi Juha, it seems you are still using a older version. Most of us use. 2.8.11 MW0LGE 21k9. Now on revision rc3 but soon rev 4.
I think your issue has been solved sinds then.
73, PD3LK
PD3LK
Post by PD3LK »
Latest update is RC4b:
https://apache-labs.com/community/viewt ... 585#p18585
I believe your issue has been solved sinds then.
73, PD3LK
JJ4SDR
Post by JJ4SDR »
I see. Thanks!
