Hermes Lite 2 problem
alemrush
Post by alemrush »
I'm asking for a friend, he is using a Hermes Lite 2 and for the moment he is running PowerSDR with no problems. He tried Thetis 2.8.11 and he had a problem when using the PS-A on ssb each time he released the ptt (mox) to return on receive the Hermes Lite 2 and his amplifier relay made a double clic .
I don't know if the problem his hardware ( Hermes Lite 2 ) or something in his Thetis configuration.
Thanks and sorry if I'm not in the good Forum section.
André
VA2WR
André / VA2WR
Re: Hermes Lite 2 problem
André,
You might not get very good answers in this forum. Most, probably all, here are Apache hardware users, not Hermes Lite 2 users.
Since Thetis works perfectly with all Apache-related openHPDR firmware, it could very well be a Hermes Lite 2 firmware issue.
It may be better to post on a Hermes Lite related forum/list/group. The software interface between Thetis and any firmware that it might be used with is documented here:
For Protocol 1: https://github.com/TAPR/OpenHPSDR-Firmw ... umentation
For Protocol 2: https://github.com/TAPR/OpenHPSDR-Firmw ... umentation
If the Hermes Lite 2 firmware is not 100% compliant with either the P1 or P2 documentation then all bets are off.
alemrush
Post by alemrush »
I will tell my friend about it.
Thanks Scott.
André
André / VA2WR
n1gp
Post by n1gp »
Hi André,
Try posting your question in this forum (if you haven't already):
https://groups.google.com/g/hermes-lite
-Rick / N1GP
alemrush
Post by alemrush »
Thanks for the infos, I will look at this Forum.
Thanks Rick !
André VA2WR
André / VA2WR
