Release: ThetisIPCat
just made a commandline tool for sending CAT-Commands via TCP/IP to Thetis:
https://www.oe3ide.com/sdm_downloads/thetisipcat/
Usage:
Just call the program. The ini-file (thetisipcat.ini) will be auto-generated in the same directory as the exe. Adjust IP & Port.
Examples:
Code: Select all
thetisipcat.exe /ZZFA00014250000 /ZZSP1 /ZZFB00014260
cmd interface.jpg (81.7 KiB) Viewed 9904 times
You can parse the output ("returndata:") for reading the returned data from Thetis
Have fun :-)
ea3aqr
Re: Release: ThetisIPCat
Post by ea3aqr »
Thanks Ernst!
Could you post an script to to change PTT state from OFF to ON or ON to OFF in just one key stroke?
Is that possible with your tool?
Very handy, Ernst!
Would the source code be available for download?
make a cmd-file, like:
ptton.cmd
c:\yourpath\thetisipcat.exe /ZZTX1
pttoff.cmd
c:\yourpath\thetisipcat.exe /ZZTX0
w-u-2-o wrote:Very handy, Ernst!
Sure ;-)
https://github.com/oe3ide/ThetisIPCat
ea3aqr
Post by ea3aqr »
oe3ide wrote:Hi,
ptton.cmd
pttoff.cmd
Looks like I'm not explaining myself well enough...
I would like to know if we can have a batch file assigned to a keystroke than can acts exactly like "space" bar on Thetis that togles ON/OFF my PTT.
I know I can use 2 .bat files but this is not what I'm looking for...
Can you explain in depth how to parse the output ("returndata:") for reading the returned data from Thetis
Sure ;-)
Thanks Ernst! :)
w9mdb
Post by w9mdb »
You can do the same with Hamlib's rigctl (rigctl-wsjtx or rigctl-jtdx).
Freq
rigctl -m 2048 --vfo -r 127.0.0.1:13013 f VFOA
18100000
rigctl -m 2048 --vfo -r 127.0.0.1:13013 m VFOA
PKTUSB
3050
rigctl -m 2048 --vfo -r 127.0.0.1:13013 get_vfo_info VFOA
18100000
PKTUSB
3050
Turn PTT on
rigctl -m 2048 --vfo -r 127.0.0.1:13013 T 1
Turn PTT off
rigctl -m 2048 --vfo 127.0.0.1:13013 T 0
PTT status
rigctl -m 2048 --vfo 127.0.0.1:13013 t
w9mdb
Post by w9mdb »
If we already have the space bar in Thetis why do you want it in another window?
I was thinking about making a utility with programmable/movable buttons that you could assign to commands like this with keyboard shortcuts too.
ea3aqr wrote:
oe3ide wrote:Hi,
ptton.cmd
pttoff.cmd
You could place a shortcut on the desktop and assign a keystroke.
Parsing: Could be done via PowerShell (never tried it):
https://stackoverflow.com/questions/205 ... and-output
w9mdb wrote:You can do the same with Hamlib's rigctl (rigctl-wsjtx or rigctl-jtdx).
Freq
18100000
PKTUSB
3050
18100000
PKTUSB
3050
Turn PTT on
Turn PTT off
PTT status
Yes correct. But I guess not for Thetis-specific CAT-commands.
w9mdb
Post by w9mdb »
rigctl -m 2048 --vfo 127.0.0.1:13013 W ZZFA; 16
rigctl -m 2048 --vfo 127.0.0.1:13013 W ZZFA00014250000; 0
The W command writes raw data and take the # of bytes expected in the return.
