still need coupler ?
elan
Post by elan »
hi
on the 7000del mark 2 black did I still need the coupler for puqrsignal
vy 73
Elan EA5IWT/G0UUT
Re: still need coupler ?
There is a proper internal coupler built into the 7000, and it is automatically selected on transmit. Don't forget, however, to enable ATT on TX in Setup > General > Ant/Filters > Antenna.
If you are using an external amplifier then, yes, you need a coupler, or you need an amplifier with a built-in coupler. In either case it attaches to the Bypass input, and you must select Bypass on TX in the settings.
elan
Post by elan »
w-u-2-o wrote:There is a proper internal coupler built into the 7000, and it is automatically selected on transmit. Don't forget, however, to enable ATT on TX in Setup > General > Ant/Filters > Antenna.
hello Scott
yes I will use the Icom 1000 amp who made this coupler do you know I think there is a German guy but cant remember his link
many thanks again for so quick and pro answer very kind of you
vy 73
Elan EA5IWT/G0UUT
elan wrote:yes I will use the Icom 1000 amp who made this coupler do you know I think there is a German guy but cant remember his link
Be careful that the coupler setup does not produce more than +13dBm maximum into the Bypass input. See also: https://apache-labs.com/community/viewt ... =20&t=2384
