anan 200d lowest power output ( a m ) mode.
Platemodulation
Post by Platemodulation »
I plan on operating a anan 200d I plan to operate mostly in the ( a m ) mode. What is the lowest power level I can run the anan 200d without affecting the audio and output.I am considering a low drive amplifier. Thanks and 73s.
KA1GXR
Re: anan 200d lowest power output ( a m ) mode.
Post by KA1GXR »
1 watt carrier. Do not exceed 25 w.from the 200D.
DL2XY
Post by DL2XY »
Minimum AM carrier is 0.25W at drive level 1.
If you need really small signal levels (0dBm) you may use XVTR output and disable the internal PA.
73 Walter
