anan 200d lowest power output ( a m ) mode.
Platemodulation
I plan on operating a anan 200d I plan to operate mostly in the ( a m ) mode. What is the lowest power level I can run the anan 200d without affecting the audio and output.I am considering a low drive amplifier. Thanks and 73s.
Re: anan 200d lowest power output ( a m ) mode.
1 watt carrier. Do not exceed 25 w.from the 200D.
Minimum AM carrier is 0.25W at drive level 1.
If you need really small signal levels (0dBm) you may use XVTR output and disable the internal PA.
73 Walter
73 Walter
