Poor quality CW and noise bursts start and end of xmits
rdwing
Post by rdwing »
I am facing an issue with my new 7000 Mk3 running v2.7 Protocol1, that has very poor transmitted CW tone with a lot of distortion on the signal, and keying clicks on both key down and key up. This is observed on all bands. The antenna is a resonant fan dipole, there are common mode chokes and ferrites, and I don't believe there is any RF coming into the shack.
The following is from CW transmitted at 100W and received on a remote receiver, via the CWX built in keyer.
CWX Thetis
CWX Thetis
Screenshot 2022-07-26 021120.png (40.78 KiB) Viewed 5798 times
CWX RemoteSDR
CWX RemoteSDR
Screenshot 2022-07-26 021124.png (64.58 KiB) Viewed 5798 times
This phenomenon somewhat occurs using the TUN button and 2TON buttons as well.
Tun+2TON Thetis
Tun+2TON Thetis
Screenshot 2022-07-26 020535.png (110.32 KiB) Viewed 5798 times
Tun+2TON RemoteSDR
Tun+2TON RemoteSDR
Screenshot 2022-07-26 020523.png (1.25 MiB) Viewed 5798 times
Part of the problem seems to be incorrect timing of the relays when stopping a transmission.
A potential clue: I have a dummy load connected to ANT2. A power meter and antenna are connected to ANT1. When transmitting into the dummy load on ANT2 with a 100W carrier, when I stop the transmission by clicking the TUN button my power meter on ANT1 registers a blip of power, which I find very interesting.
Burst at end of xmit
Screenshot 2022-07-26 175238.png (193.24 KiB) Viewed 5798 times
XMIT Options
XMIT Options
Screenshot 2022-07-26 175803.png (12.76 KiB) Viewed 5798 times
PD3LK
Re: Poor quality CW and noise bursts
Post by PD3LK »
Resonant antenna on 3901 kHz ? What ham band is that?
Can you show us a example on a appropiated HAM band part?
What happens (next) if you reduce power in few steps?
rdwing
Post by rdwing »
PD3LK wrote:Resonant antenna on 3901 kHz ? What ham band is that?
Hi, it was the 80m/75m amateur band in the US. 3.901 MHz. It is a resonant antenna, a large multi band fan dipole.
Here it is on the 40m band. Antenna SWR is about 1.5 at this freq. There's nothing else in line, the tuner is bypassed for this. Seems pretty much the same.
I've discovered another issue as well. While sending CW into my dummy load, which is attached to ANT2, some blips can be seen coming out of ANT1, which are being transmitted over the air. I was pretty surprised to see that...see image at the bottom.
From 100W to 5W, the same behavior is seen.
100w
100w
50w
50w
25w
25w
5w
5w
VNA-40m
VNA-40m
ANT2 transmissions leaking out on ANT1
Screenshot 2022-07-28 012321.png (2.05 MiB) Viewed 5725 times
dynamicfusion
Post by dynamicfusion »
Maybe shielding? Grounded?
rdwing
Re: Poor quality CW and noise bursts start and end of xmits
Post by rdwing »
It seems this is a firmware problem, and unlikely to get resolved at the moment.
rdwing wrote:It seems this is a firmware problem, and unlikely to get resolved at the moment.
How did you come by that assessment? It could just as easily be a software problem. Or perhaps no problem at all, since it does not affect everyone.
w9ac
Post by w9ac »
Can you capture the transmitted CW waveform in the time domain with an oscilloscope? That will tell us a lot about the root cause of any excessive keying bandwidth, hot-switching, etc. It may be easiest to sample at the input to your dummy load with a "T" coaxial adapter.
JJ4SDR
Post by JJ4SDR »
To "rdwing,":
Curious about the time delays on the Options form. My PTT delay is 0 and the RF delay 30 ms. Not that this necessarily explains what you are experiencing. The difference between the PTT delay and RF delay in your case is very brief compared to mine.
Options 1.jpg (29.74 KiB) Viewed 5321 times
I am not using the same Thetis version as you and also I am on Protocol 2 (radio is ANAN 7000 DLE MKII).
Thetis v2.9.06. x64 Protocol 2 v2.1.18
What W9AC suggests would be good to have.
73 de Juha
JJ4SDR
Post by JJ4SDR »
Paul,
I am wondering what the numbers are on Options 1 form in your case? Mine may be off for all I know. I have only changed the PTT and RF delays, nothing else if my memory serves.
73 de Juha
w9ac
Post by w9ac »
JJ4SDR wrote:Paul,
73 de Juha
Juha,
My CW settings won't apply to you for several reasons as I'm using a specialized Channelmaster.dll file, ASIO drivers, and some hardware modifications to optimize QSK. All delays are set very low, some to zero. As you requested, I have attached my Option 1 settings but please do not attempt to use these values.
