DX Doubler (DXD Top Ten)
NN3RP
Post by NN3RP »
Good evening all and Happy Holidays.
I've been enjoying playing with SO2V using N1MM+ and it has come to the time to switch to SO2R, if possible.
My radios:
Anan 7000DLE embedded PC system and Icom 7610
Amp: SPE 1.3K
I have gotten a DX Doubler (DXD Top Ten) device and Piexx “SO2Rxlat” device, which allows the DXD to be
used with a USB-only computer. The user manual does not have any information on the Anan setup hence my search for a solution here.
Is anyone using DX Doubler with their Anan machine? Any assistance is greatly appreciated.
Rafael / NN3RP
Rafael / NN3RP
Nation's Capital USA
Re: DX Doubler (DXD Top Ten)
Do you mean making cables? Because according to the manual the only software interface is between the DXD device and N1MM.
Do you already have Thetis interfaced to N1MM? Because I'm guessing that is also required, and for the 7610 as well.
NN3RP
Post by NN3RP »
Thanks....Yes, it is about making the cables for the Anan.
I have both Anan / IC7610 talking to N1MM....and I used them each for contesting but not together. I would like to be able to use both concurrently.
Rafael / NN3RP
Do you have the DXD manual? Are there any questions about anything except J2 or J3?
NN3RP
Post by NN3RP »
I have read the manual. I thought that it will have an entry for setting up Anan type of radio but this device is from the Flintston's era!
J2 / J3 are the 8-pin DIN. I will work in figuring out what pins to connect the Anan lines,
DX Doubler J2-J3.png (217.24 KiB) Viewed 9136 times
I think I can use the Elecraft diagram,
DX Doubler-ElecraftCable.png (81.65 KiB) Viewed 9136 times
Rafael / NN3RP
Other than it's prehistoric style LPT port for software control it's not really any different than any other two radio/four receiver mic/key/audio switchbox sold for SO2R op's.
The Elecraft cable pictured will not work. However, it does provide a nice schematic to mark up with a red pencil based on the actual pinouts of a 7000. You do have the necessary 7000 documentation to work from, I hope?
NN3RP
Post by NN3RP »
Thanks. Yes, I'll use the Elecraft as a reference.
The Piexx “SO2Rxlat” device, will allow the DXD to be used with a USB-only computer like is the case nowadays.
Rafael / NN3RP
