45LO problems
4L5O
Post by 4L5O »
After the update ANAN 7000 MKII With P2 2.1.18 , I noticed that it sometimes freezes during reception and transmission audio.
4L5O wrote:After the update ANAN 7000 MKII With P2 2.1.18 , I noticed that it sometimes freezes during reception and transmission audio.
You have one of three problems:
1. Your CPU is not fast enough for P2--solution: faster CPU, or lower IF sample rate.
2. Your network is not fast enough for P2--solution: dedicated network connection, or lower IF sample rate.
3. Your Orion MKII card doesn't like 2.1.18.--solution: go back to the first post of this topic, select a different/older version of P2 firmware, and try that instead.
If you want to debug this then please start a new topic.
4L5O
Post by 4L5O »
I have Cpu I7 (10)
ANAN directly connect to PC.
45LO problems
Then your problem is probably that your specific Orion MKII in your 7000 does not close timing properly with 2.1.18. Try a different/earlier version of P2 firmware (links in the first post of the firmware topic where you got 2.1.18).
I have started a new topic for your particular firmware problems. Please keep discussion of your specific firmware issues concentrated here.
4L5O
Re: 45LO problems
Post by 4L5O »
I tested all version P2 Firmware, and for all versions it's Seq Errors with PS-A,
Without PS-A no Seq errors.
What is the problem?
Re: 45LO problems
If there are no glitches on the audio then you can safely ignore them.
If there are glitches on the audio and you have tried all versions with no success then you have a "lemon" Orion MKII board that can't run P2.
P.S. please don't post duplicate questions in multiple topics.
4L5O
Re: 45LO problems
Post by 4L5O »
ok, thank you,
About audio i will test again,
When i use PS-A all version Seq error,
I bought ANAN 7000 DLE MK2 in JUNE 2022,
If i back from P2 to P1 can i use same Bootloader, which i used P1 to P2?
Kind regards,
Re: 45LO problems
PLEASE don't use the report button again unless there is a real problem on the forum. I see you've realized that mistake already. When you make that mistake it really riles up all the moderators!
Yes, Bootloader will load any firmware, P1 or P2. IMHO, it is the best approach to loading firmware.
