Dear friends,
Is it possible to turn off AGC altogether in Thetis? I do EME and it is useful to measure signal levels at audio where AGC just gets in the way. Note: I'm not asking about turning off "auto AGC gain mode" (which is so redundant.)
W9IP
Turn off AGC altogether?
Re: Turn off AGC altogether?
You want to set the AGC mode to "Fixd"W9IP wrote:Dear friends,
W9IP
Do you mean Setup/DSP/AGC-ALC/"Fixed Gain (dB)?
Not Walter but, yes, that's what he means. When you set the AGC to "Fixd" mode in the main UI console drop down control, it turns off AGC and uses a fixed gain that you specify that remains unvarying until you change AGC mode to something automatic.
Perfect, thanks to both of you.
