Turn off AGC altogether?
W9IP
Post by W9IP »
Dear friends,
Is it possible to turn off AGC altogether in Thetis? I do EME and it is useful to measure signal levels at audio where AGC just gets in the way. Note: I'm not asking about turning off "auto AGC gain mode" (which is so redundant.)
W9IP
DL2XY
Re: Turn off AGC altogether?
Post by DL2XY »
W9IP wrote:Dear friends,
W9IP
You want to set the AGC mode to "Fixd"
W9IP
Post by W9IP »
Do you mean Setup/DSP/AGC-ALC/"Fixed Gain (dB)?
Not Walter but, yes, that's what he means. When you set the AGC to "Fixd" mode in the main UI console drop down control, it turns off AGC and uses a fixed gain that you specify that remains unvarying until you change AGC mode to something automatic.
W9IP
Post by W9IP »
Perfect, thanks to both of you.
