Meter work
Meter work
Hey all,
We need meters, lots of meters. Still massive wip, but will be coming out at some point over next 2/3/4 weeks.
In action : https://youtu.be/4yR8VTMX548
sv1jso
Re: Meter work
Post by sv1jso »
This is a dream Richie.
Kudos my friend
SV1JSO
rbduck
Re: Meter work
Post by rbduck »
Wow Richie. Love the meters. I've ordered another PC just to carry the load. I'm very anxious to see them in action. Thank for all the great work!
Re: Meter work
Very cool Richie.
However, can the the peak and average indications for each function please be combined onto a single meter? It's much easier to read and understand that way. It's how audio information is always presented in the professional realm.
Also, there's no reason to show ALC, ALC Comp and ALC Group. ALC Group is all that is necessary as it combines the functions of ALC and ALC Comp.
Re: Meter work
@Scott , yep anything can be done, it is entirely object based with z order etc etc. I can overlay the peak date at a higher Z order easily. At the mo it is everything slapped on dx surface so I can check it all works ;)
Re: Meter work
just a quick vid of it working....
Re: Meter work
Is a S/N Ratio meter in the future at any point? IMO a S/N Ratio (SNR) meter is actually much more relevant than a simple S-meter because it actually shows the signal level relative to the noise level, which is much more valuable info than just the raw S-meter reading of a signal.
I've always believed that telling someone "You're 10 over" (but not mentioning that the noise is already S9+5) is nowhere near as informative as letting them know "You're only 5 dB over the noise".
For reference, the latest version of Simon Brown's SDR Console has a fully functional SNR meter, it performs beautifully, I use it all the time while SWL'ing.
Kind thanks,
Re: Meter work
K1LSB wrote:Richie,
It's not a meter, just a readout, but that information is currently available in the "info line" just below the spectral display. Right click that line to switch between the two pages of info available. Page 2 of 2 shows resolution bandwidth, noise power spectral density, passband noise power, and passband SNR. These numbers are all approximate since the software has to guess where noise is noise and where signal is signal, but they are pretty close.
Re: Meter work
Many thanks Scott, I never knew that!
Re: Meter work
Post by Joe »
Fantastic work on all. Thanks so much,
73’s
w4bf
Re: Meter work
Post by w4bf »
It would be wonderful if you would add some way to turn off that red history shading on the analog meters.
w9ac
Re: Meter work
Post by w9ac »
Awesome effort.
Richie, is it your current plan to display all functions simultaneously or menu-select only those metering parameters of interest to the operator?
NC3Z
Re: Meter work
Post by NC3Z »
w9ac wrote:plan to display all functions simultaneously or menu-select only those metering parameters of interest to the operator?
1:00 minute mark of video he notes that it will be configurable which ones you want to see.
W4GM
Re: Meter work
Post by W4GM »
Fantastic!!!! Welcome Back and Thanks Richie....
W4GM
W3MMR
Re: Meter work
Post by W3MMR »
K1LSB wrote:Richie,
Im not seeing this on my software. Is it in later versions than 2.9.0 x64? All I see is on Page 1, how many hz off listening frequency strongest signal is, the db level of that signal in reference to the grid on the panadapter, and the frequency of the strongest signal in passband. And page 2 on has the resolution BW by itself.
Re: Meter work
W3MMR wrote: Im not seeing this on my software. Is it in later versions than 2.9.0 x64?
You need to upgrade to 2.9.0.6.
viewtopic.php?f=9&t=4133
Follow the beta link.
Re: Meter work
K1LSB wrote:Richie,
Estimated SNR data is now presented to the meter system and rendered. Difference in numbers is due to the meter being updated much faster (adjustable) than the relatively slow snapshot on the info bar. Oh, and the magic eye is displaying signal str at the mo, well it can be calibrated to display anything in all actuality.
Re: Meter work
Richie, you are awesome !!
Re: Meter work
K1LSB wrote:Richie, you are awesome !!
Beware however, that it uses the estimated noise floor across the whole visible spectrum (the same noise floor that used for auto adjusting agc gain etc) and estimated passband noise power to make the calculations. There are a whole bunch of other factors that will change the estimated PBSNR value as well, which perhaps Scott could cover in another thread if not already.
Some useful info here from Scott : HERE
Cheers.
Re: Meter work
Cheers.
The estimate is extremely accurate, thanks to Richie's remarkably astute algorithm, I believe the same one that is used to judge the noise floor for automatic display scaling. It is rarely more than a dB off.
W1JA
Re: Meter work
Post by W1JA »
FB Richie! The TX multimeter is awesome! I'm looking forward to the future refinements. (Such as giving users a choice of colors per meter, and a choice of which meters to display.)
73! John W1JA
W3MMR
Re: Meter work
Post by W3MMR »
2.9.0.7 has been really good so far. Enjoying the meters. I am also having an issue with the cross needle meter staying up when not transmitting.I tried changing the picture file name, but it didn't work. I did not get into the code because im not real familiar with doing that and want to research what i need to do a little more, before doing it.
Thanks Richie, SIgi, and the rest for all of your contributions
Perry
ww1ssradio
Re: Meter work
Post by ww1ssradio »
Any idea as to when you will release the new meter version??
Traveling in the RV
Amateur Radio Operator WW1SS . . .
