Master AF slider not doing anything
JJ4SDR
Post by JJ4SDR »
I noticed that Master AF slider does absolutely nothing. Not sure if I have accidentally "turned off" that feature. Which form should I check?
w3ub
Re: Master AF slider not doing anything
Post by w3ub »
That only works with the speaker/headphone output directly from the radio, not VAC, I think.
Doug
JJ4SDR
Post by JJ4SDR »
Hi Doug,
I was suspecting that. Using VAC.
Doug is correct! :)
