I noticed that Master AF slider does absolutely nothing. Not sure if I have accidentally "turned off" that feature. Which form should I check?
Master AF slider not doing anything
Re: Master AF slider not doing anything
That only works with the speaker/headphone output directly from the radio, not VAC, I think.
Doug
Doug
Hi Doug,
I was suspecting that. Using VAC.
Doug is correct!
