Using a mouse to adjust off-set numbers is way too tricky and I often find that I don't hit the thumb-wheel with the pointer fast enough when working split. Is there a way to increase the size of the thumb-wheels/numbers? I assume that if I had a Midi controller I could assign a slider/button/wheel on it allowing me to quickly tweak the off-set. Short of getting a Midi controller there is likely a way to achieve what I am shooting for. I just haven't found it yet.
Would be glad to learn something new again
