Size of off-set numbers (arrows) on thumb-wheels under XIT/RIT
JJ4SDR
Post by JJ4SDR »
Is there a way to increase the size of the off-set numbers on the RIT/XIT thumb-wheels? The size of the entire window or the UP/DOWN arrows is really what I meant.
Using a mouse to adjust off-set numbers is way too tricky and I often find that I don't hit the thumb-wheel with the pointer fast enough when working split. Is there a way to increase the size of the thumb-wheels/numbers? I assume that if I had a Midi controller I could assign a slider/button/wheel on it allowing me to quickly tweak the off-set. Short of getting a Midi controller there is likely a way to achieve what I am shooting for. I just haven't found it yet.
Would be glad to learn something new again :D !
Re: Size of off-set numbers (arrows) on thumb-wheels under XIT/RIT
hover over the number box and mousewheel? 10hz steps
JJ4SDR
Post by JJ4SDR »
Hello Richie!
Apologies for not expressing myself correctly.
I mean that the UP and DOWN Arrows are really small so I am having difficulty hitting the "arrows." Would like to be able to increase the size of those arrows and/or the size of the numbers on the thumb-wheels.
Post by K9RX »
Suggestion for a change re these arrows.... it is the same thing on WS and JTDX. The UP/DWN arrows reside in one box one above the other and for my (and most) older eyes it gets to be more difficult to mouse to them ---- instead change to 2 boxes side by side with the left having a (full box/larger) UP and the right having a DWN arrow.
JJ4SDR
Post by JJ4SDR »
Gary,
How do you effect these changes?
