cmASIO feature in Thetis
OZ1CT-Ben
Re: cmASIO feature in Thetis
Post by OZ1CT-Ben »
If you se in cmASIO2 picture i have set the buffer + sample rate to 4800 /64 but the ASIO do not run !!! i can only get the ASIO to run if I use the VAC (look in cmASIO3 picture...and when I start VAC it change the samplerate to 2048 ??? why ???
the cmASIO4 show the driver version
I started to run v2.10.3.5 but upgraded to v2.10.3.6 but still no sign of the "cmASIO" on the bare
73" Ben
Behringer UMC info
Behringer UMC info
cmASIO3
cmASIO3
cmASIO2
cmASIO2
DH1KLM
Post by DH1KLM »
Does your UMC appear in Thetis audio setup if it is registrated in registry? It should not be an option to switch to and should not be displayed.
Have you tried hostsample.exe?
OZ1CT-Ben
Post by OZ1CT-Ben »
As you can see in the cmASIO5 the drive show up in Thetis Audio...there is no diference if I remove it from the Registry
Hostsample.exe ???? don't know this file ???
Ben
DH1KLM
Post by DH1KLM »
Looks like this is the point. It should not be visible if all went right.
Hostsample.exe is mentioned in cmASIO Guide.pdf and can be downloaded at https://github.com/W4WMT/Thetis/releases/tag/v0.0
It gives you informations about installed ASIO devices.
search.php?keywords=hostsample
cmASIO Guide.pdf is installed if you use the latest Thetis installer. You can also download it from https://github.com/ramdor/Thetis/blob/m ... 0Guide.pdf
OZ1CT-Ben
Post by OZ1CT-Ben »
I try this Hostsample.exe and it show this:
driverCount = 2
Realtek ASIO
UMC ASIO Driver
Press any key to continue . . .
ASIO driver: [0] = Realtek ASIO
asioVersion: 2
driverVersion: 3
ErrorMessage: No ASIO Driver Error
ASIOGetChannels (inputs: 2, outputs: 2);
ASIOGetBufferSize (min: 1024, max: 1024, preferred: 1024, granularity: 0);
ASIOGetSampleRate (sampleRate: 0.000000);
ASIO driver: [1] = UMC ASIO Driver
asioVersion: 2
driverVersion: 1337
Name: [UMC ASIO Driver]
ASIOGetBufferSize (min: 8, max: 2048, preferred: 2048, granularity: -1);
ASIOGetSampleRate (sampleRate: 48000.000000);
ASIOOutputReady(); - Not supported
AsioCanReportOverload Not Supported
ASIOGetLatencies (input: 2120, output: 2424);
channel: 0 isInput: 1 isActive: 1 channelGroup: 0 type: 18 name: In 1
channel: 1 isInput: 1 isActive: 1 channelGroup: 0 type: 18 name: In 2
channel: 0 isInput: 0 isActive: 1 channelGroup: 0 type: 18 name: Out 1
channel: 1 isInput: 0 isActive: 1 channelGroup: 0 type: 18 name: Out 2
ASIO Driver started successfully.
OZ1CT-Ben wrote:Trynig to get this cmASIO up and run on my PC.... but I dont se any "cmASIO sign" on my screen ???? if no sign then it is not working ????
I can only see the "TCP/IP Cat server" is running
73" Ben
Please check also there are no blanks after "ASIOdrivername" and the value "UMC ASIO Driver" in the registry.
In case of a "wrong" key (ie with blanks after the string) you will not get any cmASIO icon in Thetis.
In case of a wrong ASIO driver name you should get a red cmASIO icon in Thetis.
DH1KLM
Post by DH1KLM »
Have you already uninstalled and reinstalled the UMC drivers?
@Ernst, good hint about the blank entry
OZ1CT-Ben
Post by OZ1CT-Ben »
1. I uninstall Realtec + UMC ASISO driver
2. start up Thetis...no ASIO driver
3. plug in the USB-cable to my Behringer UMC202hd
4. install latest driver for UMC202HD
5. made the regkey setup ( and there was no emty field)
6. reboot PC
7. run the Hostsample:
driverCount = 1
UMC ASIO Driver
ASIO driver: [0] = UMC ASIO Driver
asioVersion: 2
driverVersion: 1337
8. Turn on Thetis and see the "cmASIO" sign on the bar :-) so now it is up and running, and the ASIO driver is not in the Audio/VAC1 driver menue.
9. BUT BUT the sound is terribel..... there is som many "cracking" that i is not good.....
back when I use the ASIO in VAC I did 48000 /8 and it works a charme...but I think I have read somvhere that I need to run 48000 with 64kb buffer ???
73" Ben
Trucker
Post by Trucker »
cmASIO doesn't work through the VAC menu settings. If you have VAC1 checked, un-select it.
OZ1CT-Ben
Post by OZ1CT-Ben »
I try now to use the ASIO driver in VAC and use the 48000 / 32 settings and also in the UMC control panel I select the same numbers.....but when Tetis start up it change the buffer to 2048 samples ???? why it do it I dont know
But the sound is mutch better....a real plesure to hear from the speaker...no "Craking"
so I know now how to setup this option...maybe this option wil be better in the next version of Thetis...I can just hope :-)
Tnx fer all help!
Ben
Try to add the following key to the registry: ASIOblocknum (DWORD 32bit) and assign a value of 5 or 6
(Using cmAsio with VM virtual asio I have to set it here to 9 in order to get a glitch-free audio)
73 de Ernst, OE3IDE
OZ1CT-Ben
Post by OZ1CT-Ben »
NOW we are close to it run....PERFECT ;-)
I have now try 5,,,7,,,,9 but now up on 15 and there is no "Craking"
will try the numbers arrund and see what is best.
sounds is good....
Thanks for help....
73" Ben
KC2QMA
Post by KC2QMA »
I wonder if most of this setup will be made easier in the future with some dropdown menus similar to how you set up VAC?
Anyway it's just nice to see ASIO in Thetis!
Thank You Thetis Dev team!!
Chipp
Post by Chipp »
Can cmASIO be used over the internet using remote desktop software?
I have been trying to use TeamViewer and Anydesk to listen to my 7000MKII. I have been unsuccessful getting any audio via cmASIO.
Interface is UM202HD. The UMC control panel displays the correct sample rate, buffer size and ASIO as active.
UMC202HD is no longer displayed as an option under VAC
In Thetis a green cm symbol is displayed in the lower ribbon.
In sound volume mixer Thetis and TeamViewer have the output device designation "OUT 1-2 (BEHRINGER UMC 202HD 192K)"
I do have audio as soon as I select VAC1 which is set to use MME.
W6MY - Chip
Chipp wrote:Can cmASIO be used over the internet using remote desktop software?
Not directly. You can pass it through Voicemeeter to one of your remote access app's.
If you have more questions about remote op's please post them in the remote op's part of the forum: viewforum.php?f=24
OZ1CT-Ben
Post by OZ1CT-Ben »
I run my Anan remote via OpenVPN,
The Thetis software run on my home PC here at home and my Anan at the temote....and cmASIO is running fine, so maybe an idea to use VPN in sted of RDP
Ben
K8EZB
Post by K8EZB »
A bit late to the party here. Just now setting up cmASIO in 2.10.3.6 dev per the published guidance. Using PreSonus 192 Mobile but Voicemeeter only for digital modes. So far, working as expected with no issues.
Rick
K8EZB
GW0NTM
Post by GW0NTM »
Hi All
Does anyone know what input channels are being used by cmASIO? Is it mono from channel #1, or a mono combination of channels #1 and #2?
Robin
GW0NTM wrote:Hi All
Robin
Mono combination.
GW0NTM
Post by GW0NTM »
GW0NTM wrote:Hi All
Robin
Mono combination.
Thank you. That explains the strange effect I was getting by running my unprocessed mic audio on channel 1 and processed audio on channel 2. I will have to come up with a new approach for getting DAW processed audio in.
R
StefanoAlvaro
Post by StefanoAlvaro »
I purchased a MOTU M2 card to test the cmASIO functionality, I created the text in regedit and everything worked fine straight away. Unfortunately I had to go back to the protocol1 firmware (I have a 7000 mk3 and the prot2 doesn't work well), the cm icon remains green but I can't hear anything anymore. I also tried resetting the db, and even reinstalling the motu and thetis drivers, but to no avail. Could it be that the cmASIO functionality only works with protocol2?
W4WMT
Post by W4WMT »
StefanoAlvaro wrote:Could it be that the cmASIO functionality only works with protocol2?
Hi OM,
Yes, that is correct, cmASIO is not supported by protocol_1.
I'll have to check why the icon is still green using protocol 1 (I thought we tested that).
As far as not being able to run protocol_2 on your MKIII, have you checked out all of Rick's N1GP firmware builds for that FPGA? He has quite a few, you might get lucky!
Bryan
K2MWC
Post by K2MWC »
I've been trying to get this cmASIO working without any success. I ran hostsample and It comes up with 3 Asio drivers
driverCount = 3
Voicemeeter AUX Virtual ASIO
Voicemeeter Insert Virtual ASIO
Voicemeeter Virtual ASIO
I've tried all 3 in the registry still no green cm at the bottom of Thetis, any suggestions ?
Can you post a screenshot of your registry entry ?
K2MWC wrote:I've been trying to get this cmASIO working without any success. I ran hostsample and It comes up with 3 Asio drivers
driverCount = 3
K2MWC
Post by K2MWC »
Tony EI7BMB wrote:Can you post a screenshot of your registry entry ?
driverCount = 3
Thanks , I have Voicemeeter Virtual ASIO set . Is voicemeeter set to INT32 LSB and 48000 ? Your sound output device should also be set to 64 /48 k .
K2MWC
Post by K2MWC »
Tony EI7BMB wrote:Thanks , I have Voicemeeter Virtual ASIO set . Is voicemeeter set to INT32 LSB and 48000 ? Your sound output device should also be set to 64 /48 k .
Yes it's set to INT32LSB 48000....i don't have any external sound devices other then external speakers that I use VAC1 to connect them.
Does voicemeeter show Hardware Out as 48/64 ?
K2MWC
Post by K2MWC »
Tony EI7BMB wrote:Does voicemeeter show Hardware Out as 48/64 ?
48/1024 which is my Speaker , trying to find the setting to change 1024 to 64
Bryan: why can't cmASIO follow the buffer size set by the device driver?
