Anan 200D, 3.3.9 .... am looking for information on how to adjust the in and output levels on the Wave File Recorder, when one makes a recording/or playback
The is a TX level adjustment but running it from +70 to -70 makes no difference in either level.
Bill - KC4PE
Wave File Recording??
Bill in Georgia
Re: Wave File Recording??
Hi Bill,
I recently recorded a DX station and played his audio back : I was surprised because the level was very low compared to my
audio from the microphone preamp (10 w vs 100 w output). I do not remenber having had this issue with PSDR 3.3.9. (i'm now
under v 3.3.15).
I also wonder if there is an adjustment to compensate for the level of a recorded audio in order to drive the transmitter output
at sam level as from the mike.
May be some one has an idea.
73s Phil FM5GB
under v 3.3.15).
73s Phil FM5GB
Bill in Georgia
Make a recording .... then put the recorded file into playback..while it's playing bring up the Wave File Drop Down ..on the mid-right you'll see a TX adjustment...while the file is playing adjust the level to match you voice TX level ...
Should be OK ... TX adjustment will not work unless a audio file is playing!!
Thank you very much Bill !
I set the gain on recorded files as you told me. I had to put 8 dB more to acheive
equal levels with mike modulation & recorde files
Now every thing is OK.
Best 73s Phil FM5GB
Best 73s Phil FM5GB
Bill in Georgia
Also ..the master and both individual audio gain controls have an effect on the input level to the wave recorder..
