Wave File Recording??
Bill in Georgia
Post by Bill in Georgia »
Anan 200D, 3.3.9 .... am looking for information on how to adjust the in and output levels on the Wave File Recorder, when one makes a recording/or playback
The is a TX level adjustment but running it from +70 to -70 makes no difference in either level.
Bill - KC4PE
FM5GB
Re: Wave File Recording??
Post by FM5GB »
Hi Bill,
I recently recorded a DX station and played his audio back : I was surprised because the level was very low compared to my
audio from the microphone preamp (10 w vs 100 w output). I do not remenber having had this issue with PSDR 3.3.9. (i'm now
under v 3.3.15).
I also wonder if there is an adjustment to compensate for the level of a recorded audio in order to drive the transmitter output
at sam level as from the mike.
May be some one has an idea.
73s Phil FM5GB
Bill in Georgia
Make a recording .... then put the recorded file into playback..while it's playing bring up the Wave File Drop Down ..on the mid-right you'll see a TX adjustment...while the file is playing adjust the level to match you voice TX level ...
Should be OK ... TX adjustment will not work unless a audio file is playing!!
FM5GB
Post by FM5GB »
Thank you very much Bill !
I set the gain on recorded files as you told me. I had to put 8 dB more to acheive
equal levels with mike modulation & recorde files
Now every thing is OK. :D
Best 73s Phil FM5GB
Bill in Georgia
Also ..the master and both individual audio gain controls have an effect on the input level to the wave recorder..
