Thetis and Norton security
n2gq
Post by n2gq »
I keep getting this message and Thetis crashes. It was idling when this happened.
Ver 2.10.3.5 protocol 2
Win 11
Anan 7000dle mkIII
Thetis security crash.png (62.2 KiB) Viewed 7547 times
Jay N2GQ
Re: Thetis has crashed
Please edit your title. Thetis has not crashed, it has been blocked by your Norton anti-virus software.
Perhaps your virus definitions updated in a way that now has Norton flagging Thetis as a problem. You may need to tell Norton to generate an exclusion for Thetis.
Do you run Thetis as administrator?
n2gq
Post by n2gq »
w-u-2-o wrote:Please edit your title. Thetis has not crashed, it has been blocked by your Norton anti-virus software.
I don't run as administrator but will try and it is already excluded.
Jay N2GQ
DO2ZA Erwin
Re: Thetis and Norton security
Post by DO2ZA Erwin »
I run also Thetis 2.10.3.5 u2 and Norton for many Years (on WIN 10 64Bit), no Problems here.
With a new Thetis Version Norton ask me and I must allow it, than is all OK.
73 Erwin
I'm not familiar with Norton, but it would seem it is not fully excluded from all checks. Achieving that level of exclusion would be a goal.
You could also test by disabling Norton temporarily.
n2gq
Post by n2gq »
w-u-2-o wrote:I'm not familiar with Norton, but it would seem it is not fully excluded from all checks. Achieving that level of exclusion would be a goal.
It does not occur all the time. It does occur on demand when I reduce the waterfall window in 4k resolution. But I am running in 1080 mode and the waterfall problem does not occur but the other day norton gave me the data protection riot act and shut it down. That was the first time it happened on its own. I am running in administrator mode and have been waiting for it to occur again.
Jay N2GQ
n2gq
Post by n2gq »
So far it's good with "Run As Administrator".
Jay N2GQ
n2gq
Post by n2gq »
Had to remove exclusion and then add exclusion again seemed stuck. Figured that one out because I could not install meters and skins. Gave me a data protection warning again. After adding exclusion I was able to install meters and skins.
Jay N2GQ
my consensus over the years has been that ones PC runs better when infected with an actual virus than it does with norton security installed :D :o
