When i try to make a recording it will fail.First when try to open the "Open Rec Folder" nothing happend.
I find out that the folder is "User\...\Music\Thetis "folder,
When i start a recording it will display in the directory "User\...\Music\Thetis " folder but when the recording is fineshed, the recording file disappear immediately from the recording directory.
So is this a bug or do i something wrong?
Using Thetis V2.10.3.6 x64 dev_4
73, Walter
PA0ALW
Thetis Memory Interface
PA0ALW-Walter
Re: Thetis Memory Interface
How do you record? When I record (via the Button on the console or the button "Record" in the wave-dialog) it puts the recorded file (SDRQuickAudio.wav) into the Thetis data folder (%appdata%/OpenHPSDR/Thetis-x64)
https://www.oe3ide.com
PA0ALW-Walter
When I record (via the Button on the console or the button "Record" in the wave-dialog) it puts the recorded file (SDRQuickAudio.wav) into the Thetis data folder (%appdata%/OpenHPSDR/Thetis-x64) that's working well.
But you can also record on schedule (Weekly or Montly) via the button "Memory" left the "Setup"button,and then it's going wrong on my side.
- Memory Interface 1.jpg (515.28 KiB) Viewed 3582 times
