Thetis Memory Interface
PA0ALW-Walter
Post by PA0ALW-Walter »
When i try to make a recording it will fail.First when try to open the "Open Rec Folder" nothing happend.
I find out that the folder is "User\...\Music\Thetis "folder,
When i start a recording it will display in the directory "User\...\Music\Thetis " folder but when the recording is fineshed, the recording file disappear immediately from the recording directory.
So is this a bug or do i something wrong?
Using Thetis V2.10.3.6 x64 dev_4
73, Walter
PA0ALW
Re: Thetis Memory Interface
How do you record? When I record (via the Button on the console or the button "Record" in the wave-dialog) it puts the recorded file (SDRQuickAudio.wav) into the Thetis data folder (%appdata%/OpenHPSDR/Thetis-x64)
PA0ALW-Walter
When I record (via the Button on the console or the button "Record" in the wave-dialog) it puts the recorded file (SDRQuickAudio.wav) into the Thetis data folder (%appdata%/OpenHPSDR/Thetis-x64) that's working well.
But you can also record on schedule (Weekly or Montly) via the button "Memory" left the "Setup"button,and then it's going wrong on my side.
Memory Interface 1.jpg (515.28 KiB) Viewed 3577 times
Please report a bug over on ....
https://github.com/ramdor/Thetis/issues ... =%5BBUG%5D
Cheers.
