Meters - next level
Meters - next level
Richie is just working on the meters / containers with external data. It opens up amazing possibilities :D
SNEAK PREVIEW ;-)
https://oe3ide.com/wordp/wp-content/upl ... xt-gen.mp4
Top Cross-Needle + Bars = Anan 7000
2nd Cross-Needle + Bars = feeded via UDP from Gemini-Multi-Control (Gemini HF-1k)
Right, above the band-buttons: Data from Gemini as text via UDP
In green, below the panafall: Cluster spots from LogHX via UDP
Big thank you Richie!
73 de Ernst, OE3IDE
ea3aqr
Re: Meters - next level
Post by ea3aqr »
Thanks also to you Ernst!
Yes, very cool, Ernst. Thank you for testing all the changes :)
To provide a bit more detail: Listeners are set up in Thetis, and at present, they can be either UDP or TCP/IP. When data arrives at these listeners, it is parsed. The data format can be JSON, XML, or RAW. Once parsed, variables and associated data are extracted and made available to the MultiMeter system. These variables can then be used in the text overlay item and as source variables for each of the existing meters.
There have been some changes to the way meter items were previously limited. Now, you can have as many power meters for example as you need in a single container—there are no limits anymore. Additionally, the maximum container count has been increased to 20.
Ernst's demo shows two groups of power meters, one for the Anan hardware, and one for his Gemini amplifier that is sending in data to the new MultiMeterIO system. The tool/status panel top right is implemented inside a MultiMeter container using the new text overlay meter item.
I will put together a video demonstrating the new features once they are a bit more complete. It might be available for testing as a development release at some point over this coming weekend.
Cheers, R.
vk1hx
Post by vk1hx »
73, Phil - VK1HX
rdwing
Post by rdwing »
Pretty neat. I think I said this in the other thread but it would be awesome to get this working for the RF2K
rdwing wrote:Pretty neat. I think I said this in the other thread but it would be awesome to get this working for the RF2K
it will come eventually, but I haven't done any client connectors yet. A quick look at the rf2k and it will need a 'request' to get the data. It is on the plan to do.
vk1hx
Post by vk1hx »
73, Phil - VK1HX
Post by W1AEX »
Richie and Ernst this project looks beautiful! Thanks for all the time and work to bring this along!
Just release a vid, looking at the input side of it. Output to follow later.
https://youtu.be/oYRrm8YpD24
and the next part, Multi Meter Io - Output
https://youtu.be/RfJ9pL-Ef8M
KC2QMA
Post by KC2QMA »
Thanks again Team for all the hard work.
John
W1SWL
Post by W1SWL »
I second this regarding the RFKIT RF2K-S amplifier... again the possibilities are endless... wow just wow...
W7GES
Post by W7GES »
Richie - Thanks! This looks terrific.
I watched the vids and it looks like it will be a piece of cake to output tcp/ip data from any of the devices connected to my Node-Red server.
I will play around with this after your release.
Now I will need to decide if I want to display power out from the amplifier or power out from the LP-700 power meter (or both).
For the guys asking for RFKIT RF2K support I see there is a Node-Red flow for it if you have difficulties getting the information from the API...
George / W7GES
If there is some interest, I could code an interface for the LP100A.
Which would connect via serial port and sends the data out via UDP. The data then could be visiualized with a Thetis meter ( bar graph, crossneedle, …)
73 de Ernst
ea3aqr
Post by ea3aqr »
Ernst,
I've detected some strange behavior...
If using %LeHM.power% variable it shows the correct FWD POWER in a text overlay container, but don't show anything in a forward power bargraph.
In a forward power bargraph, to show forward power, I must use %LeHM.powerdouble%
Is it correct that the first variable only works in the text field?
ea3aqr wrote:Ernst,
Correct. "power" gives you ie. "995 W", "powerdouble" will give you 995
ea3aqr
Post by ea3aqr »
oe3ide wrote:
ea3aqr wrote:Ernst,
Thanks for clarifying Ernst!
oe3ide wrote:If there is some interest, I could code an interface for the LP100A.
73 de Ernst
https://www.oe3ide.com/wordp/wp-content ... bridge.mp4
The new tool LP100A-UDP-Bridge (can also be used as replacement of the original Telepost VCP) is out :)
https://www.oe3ide.com/lp100-udp-bridge/
73 de Ernst, OE3IDE
nice one Ernst ! It is very cool to get these external data links up and running.
Post by Joe »
Hello Ritchie and Ernst,
This is really appreciated! The opportunities and capabilities of this are very numerous. This will allow cross communications between apps with Thetis. I'm still trying to wrap my head around this with my present setup, I have a wavenode wn-2 interfaced to a LDMOS amp that I built. I take it that I will need to wait until the "serial" option is available in the Thetis setup to explore linking to the wn-2? I know from looking at the code posted by Richie that a whole lot of work has been put into all of this. Thank you all very much.
73's
NN3RP
Post by NN3RP »
vk1hx wrote:How will it go with the SPE?
I would like to have a meter for the SPE 1.2 Expert Amplifier too. Need the how to :D
Rafael / NN3RP
Nation's Capital USA
I2NOY
Post by I2NOY »
Would be nice to have meter for OM-Power linear amplifiers that have a monitoring system over LAN, like latest models. ;)
someone with one of these amps, or access to them, needs to code up some middleware. Other option is to send me one of them :D
ea3aqr
Post by ea3aqr »
ramdor wrote:someone with one of these amps, or access to them, needs to code up some middleware. Other option is to send me one of them :D
Or both! :lol:
I2NOY
Post by I2NOY »
I can help with my OM-4001A liner amplifier but only to test if a already written middleware is working as expected. ;)
P.S. my linear weight is over 50 kg, I had troubles to move from shipping box to my desk. ;)
I2NOY
Re: Meters - next level issue
Post by I2NOY »
I followed the YouTube suggestions of Richie to setup the rotator control but I am not able to receive any packet from PST Rotator on Thetis Multi I/O.
I suspect this is due to my PC ethernet configuration as I use the laptop internal network device connected directly to Anan 7000 and the external dock station ethernet device to LAN.
On my Windows11 the internal eth is listed as Ethernet and the dock station eth is listed as Ethernet2.
Is it possible that packets of my LAN and of my terminal (127.0.0.1) are routeed only on first eth device, in my case the one connected to Anan 7000?
I tried to use putty to see the packets flowing around my IP and ports programmed on Thetis but I don't see anything and after about 10-20 seconds putty closes itself with a generic network error.
Any suggestion? ;)
P.S. I tried to set interface metric of eth card connected to LAN to 5 and eth card connected to Anan to 25, in order to prioritize tha LAN card, but the issue remains.
if you run Thetis and PST-Rotator on the same PC then the configuration should be straight forward. It doesn't matter which IP-Range the Anan7000 is using to "talk" with Thetis.
See screenshots:
73 de Ernst, OE3IDE
Thanks for the screenshots Ernst, a picture is worth a thousand words :)
If I move the rotator needle in Thetis then PST just goes to zero . Is my Thetis AZ and STOP text correct ?
AZ: <PST><AZIMUTH>%ELE%</AZIMUTH></PST>
STOP: <PST><STOP>1</STOP></PST> to <PST><STOP>1</STOP></PST><PST><TRACK>1</TRACK></PST>
