synchronize two thetis receivers
ve6ars@gmail.com
Post by ve6ars@gmail.com »
How do I synchronize the rx frequencies of two instances of Thetis, both running on the same PC? One radio is the rx/tx for digital modes and the other for rx only is on a different antenna some distance away but on the same lan. Im sure this should be simple but no amount of searching has helped. Using VSPE serial ports
Ross ve6ars
rsaue
Re: synchronize two thetis receivers
Post by rsaue »
Check out the Rigsync section of SDC - Software Defined Connectors at http://lw-sdc.com
73 de LB2EG Richard
ve6ars@gmail.com
Thanks Richard, that should do the job
Ross
N4XD
Post by N4XD »
Thanks for listing the link but link has a typo. Should be: https://www.lw-sdc.com/
Also, get an error when trying to download the manual (error says not found or something like that).
Looks like an interesting collection of capabilities.
Ron
N4XD
