Transmit Audio File BU
W4GM
Postby W4GM » Wed Jan 08, 2025 12:12 am
Where are the Transmit Audio file stored when you save them in the profile? Is there any way to import the Transmit Audio files back into a new database using Thetis v 2.10.3.8. Using older versions of Thetis before the new Database BU method it was easy to do. Maybe I'm missing something. Thanks for your help. Mike W4GM
Re: Transmit Audio File BU
Postby K1LSB » Wed Jan 08, 2025 12:57 am
Right now there isn't a way to export or import TX Profiles. Maybe that'll change someday.
W4GM
Postby W4GM » Wed Jan 08, 2025 1:36 am
Mark,
I think that you can use the option to import file into active data base to import the transmit profile into the database you’re using. Stumbled on this after my post. I haven’t actually tried it yet. I’ll try it later. Thanks!! 73, Mike
Postby K1LSB » Wed Jan 08, 2025 3:18 am
Mike,
It'd be great if you could please report back on that, I'm still not clear on how that can be done in the latest Thetis.
ea3aqr
Postby ea3aqr » Wed Jan 08, 2025 8:07 am
Please, look at this video:
[url]https://www.youtube.com/watch?v=lKlPnwRQTyY[/url]
Postby K1LSB » Wed Jan 08, 2025 2:05 pm
ea3aqr wrote:Please, look at this video:
Thanks, that vid was just posted by Richie this morning.
w4bf
Postby w4bf » Wed Jan 08, 2025 11:54 pm
So, what is the trick to get database manager to open up without it giving the message that "it can't be used while radio is powered on and must be shut down first" ????
I see in the video, he just clicks on database manager and it opens. I have to turn off power first.
Postby K1LSB » Thu Jan 09, 2025 12:42 am
Thetis was never powered on in the video.
Thetis must be powered off to access the Database Manager. That's why the message pops up.
W2PA
Postby W2PA » Thu Jan 09, 2025 12:45 am
BTW, exporting and importing transmit profiles has been possible since June 2017. See: https://community.apache-labs.com/viewtopic. ... file#p3285
What's changed recently is how exactly imports are done (i.e. better;-).
Chris, W2PA
