Transmit Audio File BU
Where are the Transmit Audio file stored when you save them in the profile? Is there any way to import the Transmit Audio files back into a new database using Thetis v 2.10.3.8. Using older versions of Thetis before the new Database BU method it was easy to do. Maybe I'm missing something. Thanks for your help. Mike W4GM
Re: Transmit Audio File BU
Right now there isn't a way to export or import TX Profiles. Maybe that'll change someday.
Mark,
I think that you can use the option to import file into active data base to import the transmit profile into the database you’re using. Stumbled on this after my post. I haven’t actually tried it yet. I’ll try it later. Thanks!! 73, Mike
Mike,
It'd be great if you could please report back on that, I'm still not clear on how that can be done in the latest Thetis.
Please, look at this video:
[url]https://www.youtube.com/watch?v=lKlPnwRQTyY[/url]
Thanks, that vid was just posted by Richie this morning.ea3aqr wrote:Please, look at this video:
So, what is the trick to get database manager to open up without it giving the message that "it can't be used while radio is powered on and must be shut down first" ????
I see in the video, he just clicks on database manager and it opens. I have to turn off power first.
Thetis was never powered on in the video.
Thetis must be powered off to access the Database Manager. That's why the message pops up.
BTW, exporting and importing transmit profiles has been possible since June 2017. See: https://community.apache-labs.com/viewtopic. ... file#p3285
What's changed recently is how exactly imports are done (i.e. better;-).
Chris, W2PA
Chris, W2PA
