wsjt remote audio
Joel1
wsjt remote audio
Post by Joel1 »
Is it possible to run piHPSDR on my ANAN G2 Ultra with panel and WSJT on my PC ( Windows ) and get the audio back and forth over LAN?
I have cat control working no problem but can't get the audio to work. Seems like most of what I'm finding is for the SDR software and WSJT to both be running on the same machine.
On the rPI I have set up virtual sinks, but not sure how to connect them to LAN. I'm starting to think my approach is bad from the beginning.
I have tried Voice Meeter Banana which seemed close, but still no connection.
what is the solution?
Joel
Re: wsjt remote audio
It would be a lot simpler to run WSJT-X on the G2 itself. There is a Linux version.
Trucker
Post by Trucker »
w-u-2-o wrote: Mon Sep 15, 2025 10:50 pm It would be a lot simpler to run WSJT-X on the G2 itself. There is a Linux version.
But, would the CM4 Pi have enough horsepower to run it along with PiHPSDR?
Trucker wrote: Mon Sep 15, 2025 11:42 pm
There's an easy way to find out ;)
One would think somebody has done this already.
Joel1
Post by Joel1 »
For me, I have been using my PC to run wsjt-x or jtdx for many years, connections are there, logbook is there, prefer to keep it there.
Still would like to know if there's a way to do audio over the LAN.
I'm 100% positive there is a way to do this. If this was Windows-to-Windows I could tell you exactly how. Unfortunately, short of doing the same Google searches you would, I don't know off the top of my head which app's to use.
A quick Google search shows that JACK runs on both Linux and Windows. I remember using JACK on Windows way back before there was Voicemeeter. https://jackaudio.org/downloads/
There is also PipeWire for Linux, but it does not seem to be available on Windows. https://pipewire.org/
Joel1
Post by Joel1 »
Thats what I have been looking into and trying. I have a null-sink setup on the CM5 and I have tried just virtual audio cable and voice meeter banana. still no luck. I think Thetis has a more explicit setup for a virtual audio channel. Once I exhaust trying with piHPSDR, I might try Thetis.
There is no VB Audio app that will work in this case. They are Windows only, and will not interface with any Linux-based solution. I.e., you've been going down the wrong road with those tools.
I'd strongly recommend you install JACK on both the CM5 and the Windows PC and see if you can get the two JACK instances communicating over the LAN.
Thetis and WSJT-X on the same Windows PC is completely trivial to interface.
Joel1
Post by Joel1 »
It also looks like running pulseaudio on both machines might work. Jack also looks like a possibility, or a combination of both. So far what I have been reading is in the context of only going in one direction. Still trying to find the right bi-directional answer.
The VB-audio answer was just for the windows side with running pluseaudio server on the linux side, but it does seem like there are better answers.
It does seem possible.
Joel1
Post by Joel1 »
Off topic, I did get it working on Thetis, was pretty simple just using VB-Audios basic virtual audio cable.
Still working on the piHPSDR solution
Return to “piHPSDR”
