With 10 meters working well here I have taken an interest in 10 FM.
When trying to access a few repeaters I have noticed that my audio level is very weak, in fact I seem to still be in AM mode with a change in Amplitude when speaking.
I have tried the Pre-emphasis before and after limiting and also disengaging the Leveler. Turning off the leveler helped a great deal with the change in Amplitude when modulating but I clearly have a center carrier spike and waveform of AM.
The Audio remains quite distant when received on another RX nearby.
If anyone here is using their ANAN 7000dle on FM with Thetis with success please drop me a line and point me into the right direction.
Can this radio do FM 5Khz Dev or not ?
FM Audio very weak and looks like Amplitude Modulation, 7000DLE
Anan 7000dle last FPGA MKIII
Firmware 2.2.2
Protocol 2 (v4.3)
Thetis 2.10.3.11
Windows 11 PC
73, Robert
KA9UVY
Firmware 2.2.2
Protocol 2 (v4.3)
Thetis 2.10.3.11
Windows 11 PC
73, Robert
KA9UVY
Re: FM Audio very weak and looks like Amplitude Modulation, 7000DLE
FM does look very much like AM, in the sense that there's a carrier and two sidebands.
You are definitely not in AM mode. If you are not used to watching FM signal spectra you might be fooled. When operating with FM, you may have to change the scaling on your TX spectrum display to see further down in signal level. Put the carrier spike near the top of the grid and make sure you've got at least 70 dB visible below that point.KA9UVY wrote: Tue Feb 03, 2026 7:56 am When trying to access a few repeaters I have noticed that my audio level is very weak, in fact I seem to still be in AM mode with a change in Amplitude when speaking.
Pre-emphasis will cause little to no difference in terms of quieting on the repeater.I have tried the Pre-emphasis before and after limiting and also disengaging the Leveler.
Turning off the leveler is exactly the wrong thing to do, regardless of what you are seeing on your transmit spectra. If you want greater average loudness you need to compress your audio dynamic range, which is exactly what the leveler and CFC do.Turning off the leveler helped a great deal with the change in Amplitude when modulating
Other than adjusting the transmit passband, I use the exact same audio settings for SSB as I do for FM ("loud"
Don't forget that your FM passband settings for RX and TX are found in Settings > DSP > FM. These settings will be saved in the transmit profile.
The default settings for maximum audio frequency are 3KHz. This provides the "traditional" modulation index of 1.63 with 5 KHz deviation and 0.83 with 2.5 KHz deviation. However you are certainly welcome to play with that.
That is what an FM spectrum looks like.but I clearly have a center carrier spike and waveform of AM.
This seems more like an audio chain setup problem than anything else. Is your mic level coming close to 0 dB? If not, add more mic gain. Same for the leveler and CFC and post-EQ output levels. ALC Group levels should hit +1 to +2 dB reliably and often, but not exceed that level.The Audio remains quite distant when received on another RX nearby.
It has nothing to do with the hardware. I.e. that you are using a 7000 is not important. All Thetis-compatible hardware, from the original Hermes to the G2 to the HL2, is essentially equivalent. They question to ask is whether or not Thetis is set up correctly. All demodulation and demodulation is done in Thetis, other than the direct frequency conversion and amplification nothing relevant is being done in the hardware.If anyone here is using their ANAN 7000dle on FM with Thetis with success please drop me a line and point me into the right direction.
Can Thetis do FM 5 KHz deviation? Of course it can, and does. Simply select the deviation setting you would like to operate with using the controls on the main console screen (right below the mic gain slider).Can this radio do FM 5Khz Dev or not ?
I've dabbled in FM on our radios and found it to work quite well, making more than a few DX contacts. Indeed, since Warren added the receive limiter function it has worked better than ever
Well, Maybe I should have chosen my words more carefully, Instead of LOOKS like let's say BEHAVES like.
My PEP power output increases by at least 50% when speaking on FM. When on AM I get more of an increase and nearly the perfect 4:1 ratio of a fully modulated AM carrier.
I do not have a lot of experience observing the FM waveform but when comparing mine to the others I'm watching, I can see that my sidebands are not well rounded, (some frequencies seem to me standing out and increasing, like AM) and my carrier spike doesn't pull down with modulation.
Besides that my local air check yesterday confirms I sound like Do Do, (weak audio).
I'll try to get my audio level to stay more consistent, and possibly experiment with a different audio driver on my FM profile.
Thanks for any constructive input.
Firmware 2.2.2
Protocol 2 (v4.3)
Thetis 2.10.3.11
Windows 11 PC
73, Robert
KA9UVY
Firmware 2.2.2
Protocol 2 (v4.3)
Thetis 2.10.3.11
Windows 11 PC
73, Robert
KA9UVY
This thread has also got me trying to effect a good FM signal out of Thetis, and I'm having some of the same issues Robert is describing (mainly less than full TUN power during FM TX).
However, another thing that concerns me is that PureSignal doesn't seem to be working on FM (at least not for me).
Is that per design intent?
I have the same issue with performance. The performance increases by approx. 60-70% during modulation.
This is the case with FM, which I am familiar with, but not with any other device. Even the measuring transmitters do not do this.
The volume can be significantly improved by activating the limiter under DSP-> FM and adjusting the gain accordingly.
Again, there is nothing intrinsically wrong with FM functionality in Thetis, or in the hardware/firmware.
I proved this to myself by injecting a single audio tone at the mic input. (Note: both TUN and Two-tone bypass all modulation stages, so there is no difference in their operation regardless of operating mode, and thus they cannot be used for this test.)
Single-tone FM will result in an output RF spectrum that is relatively easy to recognize. Here is a good reference: https://dsp.stackexchange.com/questions ... -fm-signal
When injecting a single tone through the mic input the typical single-tone FM spectrum can be seen on the DUP display. If you really want to sharpen a pencil, go through the math to ensure the spectrum is correct with respect to sideband locations and amplitudes. By doing this test it's easy to prove that the FM modulation process is working correctly. Obviously this is essentially impossible to do with the complex and time-varying nature of human speech.
Going back to the issue of poor transmit audio quality, again I can only recommend that the audio processing configuration be looked at with a fine-toothed comb, and that some compression be applied using the leveler and CFC.
The only other adjustments are, again, located in Setup > DSP > FM, and they are limited to AF bandwidth (default 300-3000 Hz), and (non-defeatable) pre-emphasis location. The normal and default setting for pre-emphasis is after the FM limiter. This is a frequency limiter to prevent over-modulation, not an amplitude limiter, and has nothing to do with the FM receive limiter. However, it has been reported that by moving the pre-emphasis to before the FM (frequency) limiter it will have the effect of additional compression on the audio and thus make it sound "louder".
PureSignal does operate in FM mode. However, because FM produces a constant power output, it does not work very well in automatic mode, and provides very little in the way of improving the transmitted signal quality. If you desire perfection (who doesn't?
), Single Cal can be used to "lock in" a PureSignal correction prior to operating FM.
That is a receiver setting and not a transmitter setting. It will certainly improve the quality of FM reception. The FM receive limiter was added back in the early part of 2023. See this topic for more information: viewtopic.php?p=23188dj1yr wrote: Thu Feb 05, 2026 6:47 am The volume can be significantly improved by activating the limiter under DSP-> FM and adjusting the gain accordingly.
Thanks for the Reply's fellas, I have been checking all the boxes and still haven't gotten things to work as good as expected as of yet.
My Audio chain is quite simple: USB Mic into Voicemeeter potato sent into Thetis via VAC (no wires to the radio except
Ethernet) using WASPI and voicemeeter VAIO in and out.
My audio works great this way producing the best AM and SSB from this radio since I have had it. Unfortunately I can't seem to add any compression in the FM mode? Only the EQ at the top ribbon of Thetis is available when FM is selected.
My audio dances around the 0 on the mic meter and ALC stays just below 0. I have tried engaging the leveler under the AGC/ALC tab and even fooled with the ALC gain setting there.
Doing on air checks today I managed to get fair audio into the listening station (still below a third party also in the conversation on a Box store Radio)
If I increase mic gain or add a Db or two into the VAC input I can get louder but then my power output Modulates Like 50% modulated AM when I speak.
The FM receive is fine but it would be nice to be able to change filter widths for weak FM reception. The limiter works fine making reception of a 20 mile away station just as loud as a local.
Scott, How would I go about adding compression to an FM profile in Thetis?
I just don't find any way to use CFC compression or broadband comp while FM is selected.
I'm watching ALC and Mic sliders simultaneously while speaking and I'm not sure what you mean about ALC Group levels?
Thanks again for any further assistance, 73
Robert KA9UVY
Robert KA9UVY
Firmware 2.2.2
Protocol 2 (v4.3)
Thetis 2.10.3.11
Windows 11 PC
73, Robert
KA9UVY
Firmware 2.2.2
Protocol 2 (v4.3)
Thetis 2.10.3.11
Windows 11 PC
73, Robert
KA9UVY
