FM Audio very weak and looks like Amplitude Modulation, 7000DLE
KA9UVY
Post by KA9UVY »
With 10 meters working well here I have taken an interest in 10 FM.
When trying to access a few repeaters I have noticed that my audio level is very weak, in fact I seem to still be in AM mode with a change in Amplitude when speaking.
I have tried the Pre-emphasis before and after limiting and also disengaging the Leveler. Turning off the leveler helped a great deal with the change in Amplitude when modulating but I clearly have a center carrier spike and waveform of AM.
The Audio remains quite distant when received on another RX nearby.
If anyone here is using their ANAN 7000dle on FM with Thetis with success please drop me a line and point me into the right direction.
Can this radio do FM 5Khz Dev or not ?
Anan 7000dle last FPGA MKIII
Firmware 2.2.2
Protocol 2 (v4.3)
Thetis 2.10.3.11
Windows 11 PC
73, Robert
KA9UVY
Re: FM Audio very weak and looks like Amplitude Modulation, 7000DLE
FM does look very much like AM, in the sense that there's a carrier and two sidebands.
KA9UVY wrote: Tue Feb 03, 2026 7:56 am When trying to access a few repeaters I have noticed that my audio level is very weak, in fact I seem to still be in AM mode with a change in Amplitude when speaking.
You are definitely not in AM mode. If you are not used to watching FM signal spectra you might be fooled. When operating with FM, you may have to change the scaling on your TX spectrum display to see further down in signal level. Put the carrier spike near the top of the grid and make sure you've got at least 70 dB visible below that point.
Pre-emphasis will cause little to no difference in terms of quieting on the repeater.
Turning off the leveler is exactly the wrong thing to do, regardless of what you are seeing on your transmit spectra. If you want greater average loudness you need to compress your audio dynamic range, which is exactly what the leveler and CFC do.
Other than adjusting the transmit passband, I use the exact same audio settings for SSB as I do for FM ("loud" :D ).
Don't forget that your FM passband settings for RX and TX are found in Settings > DSP > FM. These settings will be saved in the transmit profile.
The default settings for maximum audio frequency are 3KHz. This provides the "traditional" modulation index of 1.63 with 5 KHz deviation and 0.83 with 2.5 KHz deviation. However you are certainly welcome to play with that.
That is what an FM spectrum looks like.
This seems more like an audio chain setup problem than anything else. Is your mic level coming close to 0 dB? If not, add more mic gain. Same for the leveler and CFC and post-EQ output levels. ALC Group levels should hit +1 to +2 dB reliably and often, but not exceed that level.
It has nothing to do with the hardware. I.e. that you are using a 7000 is not important. All Thetis-compatible hardware, from the original Hermes to the G2 to the HL2, is essentially equivalent. They question to ask is whether or not Thetis is set up correctly. All demodulation and demodulation is done in Thetis, other than the direct frequency conversion and amplification nothing relevant is being done in the hardware.
Can Thetis do FM 5 KHz deviation? Of course it can, and does. Simply select the deviation setting you would like to operate with using the controls on the main console screen (right below the mic gain slider).
I've dabbled in FM on our radios and found it to work quite well, making more than a few DX contacts. Indeed, since Warren added the receive limiter function it has worked better than ever :)
KA9UVY
Post by KA9UVY »
Well, Maybe I should have chosen my words more carefully, Instead of LOOKS like let's say BEHAVES like.
My PEP power output increases by at least 50% when speaking on FM. When on AM I get more of an increase and nearly the perfect 4:1 ratio of a fully modulated AM carrier.
I do not have a lot of experience observing the FM waveform but when comparing mine to the others I'm watching, I can see that my sidebands are not well rounded, (some frequencies seem to me standing out and increasing, like AM) and my carrier spike doesn't pull down with modulation.
Besides that my local air check yesterday confirms I sound like Do Do, (weak audio).
I'll try to get my audio level to stay more consistent, and possibly experiment with a different audio driver on my FM profile.
Thanks for any constructive input.
Firmware 2.2.2
Protocol 2 (v4.3)
Thetis 2.10.3.11
Windows 11 PC
73, Robert
KA9UVY
This thread has also got me trying to effect a good FM signal out of Thetis, and I'm having some of the same issues Robert is describing (mainly less than full TUN power during FM TX).
However, another thing that concerns me is that PureSignal doesn't seem to be working on FM (at least not for me).
Is that per design intent?
dj1yr
Post by dj1yr »
I have the same issue with performance. The performance increases by approx. 60-70% during modulation.
This is the case with FM, which I am familiar with, but not with any other device. Even the measuring transmitters do not do this.
The volume can be significantly improved by activating the limiter under DSP-> FM and adjusting the gain accordingly.
Again, there is nothing intrinsically wrong with FM functionality in Thetis, or in the hardware/firmware.
I proved this to myself by injecting a single audio tone at the mic input. (Note: both TUN and Two-tone bypass all modulation stages, so there is no difference in their operation regardless of operating mode, and thus they cannot be used for this test.)
Single-tone FM will result in an output RF spectrum that is relatively easy to recognize. Here is a good reference: https://dsp.stackexchange.com/questions ... -fm-signal
When injecting a single tone through the mic input the typical single-tone FM spectrum can be seen on the DUP display. If you really want to sharpen a pencil, go through the math to ensure the spectrum is correct with respect to sideband locations and amplitudes. By doing this test it's easy to prove that the FM modulation process is working correctly. Obviously this is essentially impossible to do with the complex and time-varying nature of human speech.
Going back to the issue of poor transmit audio quality, again I can only recommend that the audio processing configuration be looked at with a fine-toothed comb, and that some compression be applied using the leveler and CFC.
The only other adjustments are, again, located in Setup > DSP > FM, and they are limited to AF bandwidth (default 300-3000 Hz), and (non-defeatable) pre-emphasis location. The normal and default setting for pre-emphasis is after the FM limiter. This is a frequency limiter to prevent over-modulation, not an amplitude limiter, and has nothing to do with the FM receive limiter. However, it has been reported that by moving the pre-emphasis to before the FM (frequency) limiter it will have the effect of additional compression on the audio and thus make it sound "louder".
PureSignal does operate in FM mode. However, because FM produces a constant power output, it does not work very well in automatic mode, and provides very little in the way of improving the transmitted signal quality. If you desire perfection (who doesn't? ;) ), Single Cal can be used to "lock in" a PureSignal correction prior to operating FM.
dj1yr wrote: Thu Feb 05, 2026 6:47 am The volume can be significantly improved by activating the limiter under DSP-> FM and adjusting the gain accordingly.
That is a receiver setting and not a transmitter setting. It will certainly improve the quality of FM reception. The FM receive limiter was added back in the early part of 2023. See this topic for more information: viewtopic.php?p=23188
KA9UVY
Post by KA9UVY »
Thanks for the Reply's fellas, I have been checking out all of the settings and still haven't gotten things to work as good as expected as of yet.
My Audio chain is quite simple: USB Mic into Voice meeter potato sent into Thetis via VAC (no wires from PC to the radio except
Ethernet) I'm using Windows WASPI driver and voice meeter VAIO in and out.
My audio seems to work great this way, IMO producing the best AM and SSB from this radio since I have had it.
My audio does behave somewhat erratic and passes +3 when I start to TX and then settles down to -3 on the mic meter while the ALC stays just below 0. I have tried engaging the leveler under the AGC/ALC tab and even fooled with the ALC gain setting there but after I hit the wall on loudness (still low as compared with others) I can only introduce distortion.
Doing on air checks today I managed to get fair audio into the listening station (still below a third party also in the conversation on a Box store Radio)
If I increase mic gain or add a Db or two into the VAC input I can get louder but then my power output Modulates Like 50% modulated AM when I speak.
The FM receive is fine but it would be nice to be able to change filter widths for weak FM reception. The limiter works fine making the volume of a 20 mile away station more or less equal to that of a local station.
I don't want to change compression in Potato since it would affect my AM and SSB profiles and they are working quite well. I need an FM profile specific solution to smooth out my audio.
Since the VOX,DEXP and COMP controls and selectable filters disappear when FM Mode I will have to try the DSP>CFC compression section that I haven't really used before.
Scott, you said:
"This seems more like an audio chain setup problem than anything else. Is your mic level coming close to 0 dB? If not, add more mic gain. Same for the leveler and CFC and post-EQ output levels. ALC Group levels should hit +1 to +2 dB reliably and often, but not exceed that level."
Scott, I believe you are correct and I will try adding some compression in the DSP CFC settings. I also made an FM profile using different driver to try.
I'm watching ALC and Mic sliders simultaneously while speaking and I'm not sure what you mean about ALC Group levels?
Should I add any other meters to the container?
Thanks again for any further assistance, 73
Firmware 2.2.2
Protocol 2 (v4.3)
Thetis 2.10.3.11
Windows 11 PC
73, Robert
KA9UVY
KA9UVY wrote: Fri Feb 06, 2026 5:48 pm
With that setup you should consider switching to cmASIO. See the cmASIO help document that it installed in the same directory thetis.exe lives in. However, that suggestion is just a setup optimization thing, and has nothing to do with your audio issues.
That is not indicative of a problem. I recommend you stop stressing over the output spectrum and power.
Changing passband filter widths is not relevant to FM mode. The passband filter is set to match the deviation of the FM signal. Wider just introduces noise. Narrower degrades SNR and audio quality. There are no gains to be had here.
Yes, that change made FM actually usable in Thetis. It was a longstanding oversight in the FM receiver design.
No need for that. Thetis includes everything you need and, in most cases, is more advanced than the processing available in Potato.
Gone but not forgotten! Just another symptom of a an old UI getting older and not keeping up with the millions of things Thetis can do.
All of these audio processing stages are accessible via the setup menu, even when their buttons are missing from the main console UI. Take a tour of the tabs available in Setup > DSP. You will find everything except COMP (which is in the Transmit tab) and the original TX EQ (which is in the Equalizer menu pick at the top of the window).
NEVER use COMP. It is old, outmoded, and sounds terrible. Use CFC instead.
ALC Group is a mashup of ALC and ALC Comp. The problem with the original setup is that it was not ergonomic. ALC only showed you the ALC level until it reached 0 dB. ALC Comp only showed you the ALC level when it went over 0 dB (and when it went over by say 2 dB, the compression invoked was 2 dB to get it back down to 0, hence the name, "ALC Comp"). With both metering modes combined together in ALC Group it is much easier to see what is going on instead of jumping back and forth between two different metering modes.
As for additional meters in a container, for now it's probably worth building a container that has the entire available audio chain metering list, in order: Mic, Leveler, Leveler Gain, EQ, CFC Compression, ALC Group. Just to keep an eye on things ;)
dj1yr
Post by dj1yr »
w-u-2-o wrote: Thu Feb 05, 2026 3:41 pm
Yes, you're right, I just listened back over the 2nd RX.
As for the main problem, with a single tone or two tones at a constant level, it's not noticeable.
Try speaking into your radio in FM mode, and you will see the high AM component.
I also have Flex, and it doesn't exhibit this behavior.
It would be normal if the signal were completely overmodulated and became too wide, causing the channel power to drop, but that's not the problem.
I can observe this behavior on the 200D, Orion MKII, and Anvelina ProIII; no other device does this for me.
73`René
