x-Axis vs peak-blobs vs rx-meter
maybe it is a silly question, but which values are represented on the x-axis and the peak-blobs. It seems to be not related to the rx-meter.
See yellow marked areas in the screenshot (right click => open picture in new tab for full-image)
Thanks & 73 Ernst
I4LEC
Re: x-Axis vs peak-blobs vs rx-meter
Post by I4LEC »
Hi Ernst,
it is refered to the bin bandwidth, which given the 26dB difference, should be set at 7.4Hz
10 log (2960/7.4) = 26
73, Clay
Great post by Scott a while ago with explanation.
https://apache-labs.com/community/viewt ... =itu#p2999
Thanks for the explanation !
Just as an aside, since I reset my database and built it by hand again with the fast and furious pace of Ritchie's updates, I like to calibrate my S-Meter using the built in Cal tools. I use a Rohde & Schwarz sig gen and found that the stock S-meter and Spectrum call was off by .6 dB @ -73dB. Pretty damn good for no cal, but I still calibrated to be nuts on :lol:
Freq cal was off tad also, but WWV is always handy.
