Thetis > SDC using VAC - Ghost Signals
m0cke
Post by m0cke »
Hi all
I'm using Thetis > SDC using IQ via VAC, however looking at SDC skimmer I can see ghost signals, these are also reported as spots on the panadapter.
Is anyone else experiencing this please?
What could be the cause?
Jim M0CKE
Re: Thetis > SDC using VAC - Ghost Signals
Go to Setup > DSP > Options.
If they are not already set like this, try changing filter type to linear phase and filter size to 1024.
m0cke
Post by m0cke »
w-u-2-o wrote:Go to Setup > DSP > Options.
Thanks, they weren't set to this, will give that a try!
Jim M0CKE
Make sure you have IQ swap enabled in Thetis. The last time I spoke to Yuri he was in the middle of removing that option in SDC, but IQ does need to be swapped otherwise you will probably get decodes and signals in very odd places. As a side note, at least on my install, I have not had any reason to adjust the filters to get it to work when using IQ over vac.
StefanoAlvaro
Post by StefanoAlvaro »
A strange thing happens to me with SDC, when I transmit I see my transmission appear on multiple frequencies. I tried excluding the dup, the ps, lowering the power to 1w (if I transmit at 0w it doesn't happen). What could it depend on?
