Using MOX vs PTT different transmit eq
n2gq
Post by n2gq »
When using MOX vs PTT I get a different transmit eq during transmit It sounds thinner or not processed/adjusted. I discovered this while adjusting the dexp.
Using Thetis v2.10.3.5 x64 7000dle mkIII protocol2
I reset database but the same.
Jay N2GQ
Re: Using MOX vs PTT different transmit eq
I cannot duplicate your results.
Is the DEXP and everything else 100% identical across the board except for the state of VOX?
What happens when you use MOX with VOX enabled?
n2gq
Post by n2gq »
w-u-2-o wrote:I cannot duplicate your results.
Yes everything is the same I have checked the eq, mic, dexp and xmit filter.
I forgot to mention that this is with mic plug into front mic jack and ptt from rear of radio. Going to check vac in the morning.
Jay N2GQ
n2gq
Post by n2gq »
Okay this seems to happen only with my electret mic. It seems that the audio is lower if I use the MOX button. But If I use my dynamic mic there is no difference in xmit audio level whether I use physical ptt or mox. Maybe something with bias voltage switching in.
Jay N2GQ
n2gq wrote:Okay this seems to happen only with my electret mic. It seems that the audio is lower if I use the MOX button. But If I use my dynamic mic there is no difference in xmit audio level whether I use physical ptt or mox. Maybe something with bias voltage switching in.
Assuming you mean "PTT switch" where you wrote "MOX button", there's a good chance that the electret mic element is somehow entangled with the PTT line on the mic jack in a way that changes how it works electrically when the PTT line is grounded during TX.
See this topic: viewtopic.php?f=12&t=2573
n2gq
Post by n2gq »
No the PTT works fine. Just the MOX on thetis is where the problem is for me. I tried the bypass vac switches tick them off then on. I will continue to look into the problem. I am going to measure voltage.
Just purchased a Presonus studio 26c and will configure that in a few.
Jay N2GQ
n2gq
Post by n2gq »
Okay it has something to do with the connector I'm using at the front of the radio. Ground disconnected cold solder joint. The old wiggle test worked. :lol:
download/file.php?id=3393 don't buy this connector the body disconnects from the trs if you tighten the shell.
Jay N2GQ
That's a beautiful connector!
n2gq
Post by n2gq »
w-u-2-o wrote:That's a beautiful connector!
No stop on shell so it pushed out the connector you lose ground. But that was not my problem the shield was disconnected.
Jay N2GQ
K4IBC
Post by K4IBC »
Those are very easy to over tighten. There should be a small gap between the barrel and the 90 Degree body. If you over tighten you suck the internals into the barrel like you have there. This is where the old fashion ugly flat 90 degree works better. You solder direct to the back of the contacts and the cover is held on with small screws. Just have to becareful not to short out to the cover/sleeve.
n2gq
Post by n2gq »
Those are very easy to over tighten. There should be a small gap between the barrel and the 90 Degree body. If you over tighten you suck the internals into the barrel like you have there. This is where the old fashion ugly flat 90 degree works better. You solder direct to the back of the contacts and the cover is held on with small screws. Just have to be careful not to short out to the cover/sleeve.
Yes, next time I am going to order the switchcraft connector. But now I am using the cmASIO and man it works good.
Jay N2GQ
