RX2 not receiving
KC4MNE
RX2 not receiving
Post by KC4MNE »
7000DLE MKII RX2 stopped working. Could it have been a strong signal fried the front end?
Re: RX2 not receiving
Given what little we've been told so far, that's a possibility that shouldn't be summarily dismissed.
N4XD
Post by N4XD »
If you mean the signal connected to ADC 2, I've had a similar issue. Seems the previous owner had input a high level signal into RX2 (ADC 2). It fried the filter labeled RLP-40 and the back to back diodes labeled D22 (part number GBLCo3C) . I was still receiving but signals were at least 6dB down from what the other receiver was seeing.
The filter was not easy to replace since it has leads on all 4 sides. I don't have the correct hot air tools to remove such a device so I carefully cut it up with a demel tool and removed each piece. VERY steady hands required to solder the new device in.
The diode pack was easier as, if I recall right, its just 2 leads. After replacement all is good.
I'd estimate total time was around 2 hours, most of which was occupied in removing the board for service. Access to each device was pretty good.
Good luck!
Ron
N4XD
