Hello guys,
I have previously use the VAC with the Voicemeter ASIO driver and Voicemeter banana to able to insert my DAW ( Digital Audio Worstation ) without any problem .
My question is :
If i want to use the CMASIO driver features can i link my DAW with it ?? even with Voicemeter Banana like before or better ?
I try to figure out how to make it and if this way would be more usefull ? but no any succes so far .
Thanks in advance
73's Michel VE2XK
CMASIO , DAW and Voicemeter
VE2XK-Michel
73's Michel VE2XK FN08XJ
https://www.qrz.com/db/VE2XK
SDR user since 2012
ANAN G2 ULTRA 12/2024 - Thetis
FLEX 5000A RX2 ATU since 12/2012 with Darrin KE9NS PowerSDR
Virtual Audio for E-SSB and E-AM
SDR user since 2012
Re: CMASIO , DAW and Voicemeter
It works exactly the same as with VAC. The only difference is that you are setting up the correct Voicemeeter drivers in the cmASIO configuration rather than in the VAC configuration.
As for the DAW, I assume you are using the Voicemeeter VAIO Insert driver to move audio between Voicemeeter and the DAW? If not, then that's the best way to do it.
VE2XK-Michel
Thank you Scott,
I try to figure how to make it but no success so far . I will surely need some help or screenshot or any example of CMASIO config i guess .
«As for the DAW, I assume you are using the Voicemeeter VAIO Insert driver to move audio between Voicemeeter and the DAW» Yes i use Voicemeeter Insert Virtual ASIO on AudioMulch
Will CMASIO take any avantage over the VAC by using a insered DAW ?
include my present configuration over the VAC
Michel VE2XK
Michel VE2XK
- setting audiomulch.jpg (48.08 KiB) Viewed 103 times
- Voicemeeter Virtual ASIO.jpg (109.99 KiB) Viewed 103 times
SDR user since 2012
SDR user since 2012
cmASIO will be faster as it runs with, and only with, a buffer size of 64. It also carries both RX1 and RX2 audio, i.e. the same stream that comes from the headphone or speaker output on the ANAN. This is in contrast to VAC which splits RX1 and RX2 across VAC1 and VAC2.
cmASIO is, IMHO, conceptually simpler to use.
You can find clear directions on how to use cmASIO in the cmASIO help document. That document is installed in the same directory where thetis.exe resides.
VE2XK-Michel
Hi again Scott,
I'm sorry but i have try everything i can do but that's not work on this side .
I will keep like it was before .
Thanks for your time .
73's Michel
73's Michel
SDR user since 2012
SDR user since 2012
