First Attempt with AMP Running
LarryW
Post by LarryW »
I just got the new coupler from WaveNode Inc. This is the first try with PS running the amp.
Amp is a Acom 1500 running 500 watts output. Looking at the AmpView window, it appears we are ready to roll.
Any comments good or bad?
Larry
7000 mkll Thetis v2.8.11 21k3
P2_v2.0b
Re: First Attempt with AMP Running
It looks fine. What step attenuator value are you getting during transmit at 500W?
LarryW
Post by LarryW »
w-u-2-o wrote:It looks fine. What step attenuator value are you getting during transmit at 500W?
14-15db
P2_v2.0b
That's fine. It looks like you are in business.
SA3ATF
Post by SA3ATF »
Funny Larry to see you have the same setup as I have. Has a 200D with an Acom 1500 also with WaveNode equipment for the whole shack.
It works well for me too.
LarryW
Post by LarryW »
Awesome---- Thank You for the help!
P2_v2.0b
N4XD
Post by N4XD »
I too am just starting with Pure Signal. Using Thetis with a 7000dle.
Where do you read the step attenuator with Pure Signal?
Ron
N4XD
When you are transmitting the ATT (or S-ATT if you've switched it to that mode) indicator at the lower left part of the main console will show the step attenuator value being used.
N4XD
Post by N4XD »
Thank you sir. i thought that might be the case but wanted to verify.
Ron
Mr S
Post by Mr S »
I'm seeking a similar setup; which coupler did you order and how it is connected?
Happy Holidays
LarryW
Post by LarryW »
I just ordered his standard HF-1 with the added RF Port. This sensor needs to be inline between the antenna and the output of the amplifier.
I have since bought the LP-700 and am happy camper!
Larry
P2_v2.0b
Mr S
Post by Mr S »
LarryW wrote:I have since bought the LP-700 and am happy camper!
LP 700 is from Telepostinc, and coupler from WaveNode
I didn't know the 2 are compatible :shock:
HF-1 w/ RF view I supposed.
I can't figure out how the two are connected :?:
