MultiRX range
MultiRX range
How can i increase the range of the MultiRX so i can monitor vfoA and vfoB at the same time?
Re: MultiRX range
Could you please describe an example of a configuration that doesn't work for you?
DO2ZA Erwin
Re: MultiRX range
simply use the Zoom
Edit: Of course, only in the same Band and a high Samplerate 384000 or moore
73 Erwin
simply use the Zoom
73 Erwin
Re: MultiRX range
Right Here is on 10m and it wont let me activate it at that span. thats at a 768000 sample ratew-u-2-o wrote:Could you please describe an example of a configuration that doesn't work for you?
- Screenshot 2023-08-15 163955.png (753.62 KiB) Viewed 4209 times
Re: MultiRX range
i can increase the sample rate to 1536000 and can so may just do it that way. ty
Re: MultiRX range
Of course it won't. 29224 KHz - 28100 KHz is 1124 KHz. That is well outside your chosen sample rate, i.e. IF bandwidth, of 768 KHz.ki4tga wrote:Right Here is on 10m and it wont let me activate it at that span. thats at a 768000 sample rate
You will be able to do this if you change your sample rate (IF bandwidth) to 1536 KHz.
Re: MultiRX range
yes on my next post i did so. ty for the quick response. i was unaware that sample rate=bandwidth. ty
